Peterbilt Switched CB Circuit?
Discussion in 'CB Radio Forum' started by pdh, Jan 18, 2014.
  1. pdh
    pdh Bobtail Member
    7
    Jan 16, 2014
    Getting used to a new to me Peterbilt 385. The CB circuit I am connected to appears to be a non-switched circuit? Will I also find a pigtail for a switched circuit in the headboard area if I look long enough?
  3. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    I would check each fuse in the fuse block with a test lamp and see how many and what are switched.
  4. Powder Joints
    7,988
    8,407
    Sep 25, 2007
    Rosamond, SoCal
    No. You can go to the fuse box and find the cb radio fuse and pull it. then determine with is the radio side and which is the power side.Take about a 6" long piece of 14 gauge wire with a fuse in it (you can buy it this way at a autoparts store) pull the fuse out of the wire and insert the fuse from the fuse box that used to run the radio. Plug one end of that wire into a switched fuse (hot side) and the other into the radio side where you pulled the fuse in the fuse box.
    Or ask your shop to do this for you. I used to build fire and police vehicles and this is exactly how I would have wired it any vehicle. Check with your shop and do not forget the fuse it is there to protect the truck not the radio. Always fuse everything you install. 3 to 6" and there should be a fuse.
    pdh Thanks this.
  5. pdh
    pdh Bobtail Member
    7
    Jan 16, 2014
    Thanks - that is exactly the kind of creative idea I was looking for. Much obliged.
  6. Powder Joints
    7,988
    8,407
    Sep 25, 2007
    Rosamond, SoCal
    In a previous life I had a radio shop where we built Police, Fire, etc.. Radios Light Bars, Sirens and we had to frequently set stuff up to happen when the operator of the vehicle would flip a certain switch. Glad to help.
