Phantom rev limiter?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HillbillyDeluxeTruck, Jul 1, 2020.
  1. HillbillyDeluxeTruck
    5,942
    30,372
    Mar 3, 2013
    San Antone
    2012 Peterbilt 386 with an ISX.
    Randomly my truck in 10th gear will not rev above 1570rpm. The pedal goes dead, boost drops off and the truck will not accelerate any more. Normally it will spin to 1640rpm in top gear. While I don't drive fast enough to hit that limiter, there are times when Im passing someone and need the extra rpm to pass them quickly. This problem can last for days/weeks/months then go away.
    Im going to inspect the speed sensor on the transmission to start, but can a camshaft position/speed sensor cause this? I am getting a random stored code for the CPS, but the truck always starts and runs perfect. Not even a hiccup.
  3. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,356
    Nov 1, 2017
    The Sticks, Idaho
    Soumds like you might need an exrosist... Lol
    Rideandrepair Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,547
    6,638
    Aug 26, 2014
    An older Pet I worked on had two transmission speed sensors. Others had one sensor with four wires that work the same way.
    Back to the older everything else worked fine. When that sensor acted up RPM on the N14 was limited to 1500 RPM.
    If you can be code free solves many problems. Sorry I don't know much about the CPS on your truck.
