Phasing driveshaft
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by insanityeight, Jun 17, 2020.
  1. insanityeight
    insanityeight Light Load Member
    291
    113
    Jul 26, 2013
    birmingham al
    Pete 579. All info says to phase driveshaft that the ears on both ends must line up. Dealer says some trucks set up at factory could be 90 degrees off each other like a Plus sign. Mine are about 40 degrees from each other. Think ill try the perfectly lined up method unless someone knows better on a 2016 579 pete.
  3. Goodysnap
    Goodysnap Road Train Member
    3,769
    9,189
    Jul 12, 2017
    Intermediate shaft between axles will look wrong and phased 45* from the factory and is correct.
    Main drive line should be in line.
    If you think its been moved have it balanced and marked. Driveshafts should always be marked on removal and put back just the same.
  4. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    Well idk if it was 45 degrees , probly close but i put it straight in line ear to ear and no difference that i can tell. Same vibration. Especially when stopping
    Klalston Thanks this.
  5. Goodysnap
    3,769
    9,189
    Jul 12, 2017
    Driveline vibrations will not change when braking. You most likely have something going on in a wheel end.
    Driveline vibrations will usually change accell to decell.
    What did you find with your brake problem?
    spsauerland and pushbroom Thank this.
  6. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    Front left hub wasnt centering drum correctly so new hub drum n shoes. Vibrates like hell when stopping
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Ck that you have the correct drum for the new hub that you bought?
    BoxCarKidd Thanks this.
  8. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    It is. The braking vibration from fromt wheel is gone. It was warping drums and isnt anymore. Just still have a shimmy somewhere behind the cab i cant figure out
  9. Deere hunter
    2,118
    10,004
    Aug 5, 2017
    Shallowater Texas
    Have you ck’d stabilizer bars from frame to Top of housing?
  10. insanityeight
    291
    113
    Jul 26, 2013
    birmingham al
    Nahh. Jus jacked her up n put it in hear and got out and these cheap ### chinese tires are all wobbling like crazy. Guess thats my vibration
    Itsbrokeagain and Deere hunter Thank this.
  11. Deere hunter
    2,118
    10,004
    Aug 5, 2017
    Shallowater Texas
    Necessity is the mother of invention!!!!
