Physical demands of oilfield driving (age 38 too old)?
Discussion in 'Oilfield Trucking Forum' started by Zonno, Aug 8, 2025.
  1. Zonno
    Zonno Medium Load Member
    335
    210
    Jun 11, 2018
    South Ga
    At age 38 I’m in fairly decent shape in that I can get in & out of my truck and walk up & down a flight of stairs without getting winded. I can climb on top of my dump trailer to shovel hardened asphalt out, and I also work out at home. That being said, I’m not in great shape like a 25 yr. old. My knees and lower back don’t really hurt or ache, but I can tell they’re a bit on the stiff side. And while climbing in my truck & trailer is not necessarily hard like it is for some older drivers, I can already tell it’s a little more difficult compared to only 2 years ago. Also, I don’t want to get into food service because I doubt my body would last long.
    All this being said, would it be a bad idea for someone like me to pursue a driving career in the oilfield? I’d probably start out as a water truck driver or maybe a frac sand hauler. There are various different jobs in the oilfield, and some of them are extremely physically demanding. I don’t mind getting out to carry and couple/uncouple hoses, install tire chains, etc. But I already know I’m not a “roughneck”.
  3. O.Henry
    O.Henry Road Train Member
    1,329
    2,959
    Sep 1, 2012
    San Antonio,TX.
    I did water truck in my early 50’s.
    Wrestling the hoses in the heat,and running from scorpions were the 2 most physical things I did.Overall it’s not bad.
  4. Zonno
    335
    210
    Jun 11, 2018
    South Ga
    That doesn’t sound bad at all. To be fair, I don’t mind getting out of the truck on occasion to get the blood flowing. And I actually enjoy the 5-10 minutes using the shovel or pickaxe to remove dried asphalt, as it’s good for the biceps & shoulders. But I wouldn’t want to do it for hours on end. If I wanted to use the shovel all day long, I’d just get on the paving crew.
    Trucker61016 Thanks this.
  5. Kyle G.
    Kyle G. Road Train Member
    3,914
    20,654
    Jan 23, 2016
    Eastern Iowa
    I love that this is considered "in shape" in this industry!
    Mattflat362, Oxbow, Sons Hero and 6 others Thank this.
  6. Trucker61016
    Trucker61016 Road Train Member
    1,726
    4,914
    Sep 18, 2017
    Linville, Va
    :naka: what truckers think they look like when big lol !!!
  7. Zonno
    335
    210
    Jun 11, 2018
    South Ga
    “Fairly decent” were the operative words there.
    In any event, can a trucker make it in the oilfield without having to be a roughneck?
    austinmike, Kyle G. and Trucker61016 Thank this.
  8. RockinChair
    RockinChair Road Train Member
    5,574
    15,700
    Feb 19, 2012
    Corpus Christi, TX
    Yes. I'm livin' proof of that.
    If you're hauling water, crude, frac sand, or NGL then you'll be just fine.
    You'll work harder if you drive a pump truck, because those guys have to handle iron pipes and swing a sledge to tighten and loosen the hammer unions.
  9. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,064
    2,298
    Dec 15, 2021
  10. Trucker61016
    1,726
    4,914
    Sep 18, 2017
    Linville, Va
    o_Oo_O unless you fall in , then you got problems
    broke down plumber and austinmike Thank this.
  11. pyriteinmatrix
    pyriteinmatrix Bobtail Member
    6
    13
    Dec 18, 2017
    For the most part, hauling sand is very easy as far as physical labor goes, but the water/vac truck thing can be entirely dependent on the amount of activity in an area and customer requirements. If there is a ton of drilling, fracking and production going on in the area you are working in, then it can get really hectic physical labor wise.
