Pipe load
Discussion in 'Flatbed Trucking Forum' started by superdutyfan, Mar 3, 2021.
  1. superdutyfan
    superdutyfan Light Load Member
    86
    76
    Mar 14, 2020
    So I am picking up a load of pipe 45k lbs. Not sure of the length. It will put me at 79k lbs
    53 ft flat deck.
    Am I better off to be closer to the trailer tandems so when I split the axles it will add about 1800 lbs to the drives ? Or just try to put in the middle of the drives and trailer axels ? Or other option is to put in the middle of the trailer but when I have done this in the past it puts to much weight on the trailer axels
    I waz thinking having the start of the load at just the middle of the REAR drive axel
  3. LTL Bull
    LTL Bull Road Train Member
    1,561
    6,569
    Mar 12, 2020
    I have a 48’ spread and I always center the load about 3-4 feet behind the centerline of the deck FWIW. By your figures your rare weight is 34k? Seems heavy
  4. 389BPete
    389BPete Bobtail Member
    I usually split the difference.
  5. superdutyfan
    86
    76
    Mar 14, 2020
    Yes heavy trailer
  6. superdutyfan
    86
    76
    Mar 14, 2020
    Yes its a heavy trailer
    I put it above the rear drive axle the load is 51 joints of 6 inch pipe 40 ft length with tandems split it came just past the rear axle on the trailer.
    Stopped at Flying J and went on the scale (took 45 mins for them to figure out how to weigh split axles before they phoned cat)
    Steers 11680
    Drives 28740
    Front trailer axle 18200
    Rear Trailer axle 18720
    Total 77340
    With 1/4 on the fuel gage
    Load was lighter than expected
  7. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    You dont need to split weigh a spread on The cat scales, yes as shown above the axles are slightly different, but unless youve got 39000+ on the spread, youre going to be fine, just take trailer weight and divide by 2 for individual axle
    For exact weight center, though this can vary somewhat (usually about 6 inches +/-) as a rule of thumb, mark where the center of trailer axle grouping is, mark where your kingpin is, in the center of that is your weight's center. Now mark there.
    For a uniform load as you stated at 40 foot, 20 foot forward lay a block, no peice should go forward of that. Tadaaa, your load is now balanced between trailer and drives. Worried about weight? Open the spread and load it 2 feet closer to the rear, now youre tail-heavy but not by nearly 9000 lbs :p
    superdutyfan Thanks this.
  8. Landincoldfire
    Landincoldfire Heavy Load Member
    927
    5,124
    Sep 27, 2015
    New Holland, Pa
    I run into this more than I like to with big loads. Pretty much have to walk in and tell the cashier how to weigh the truck. The horror in their faces when one wants to weigh 11 to 13 axles of joy.
    kylefitzy, Cat sdp, beastr123 and 2 others Thank this.
  9. Espressolane
    18,690
    117,149
    For a CAT scale to do a split weights, all they have to do is press the split weight button on the main screen, then follow the instructions. If needed, they can call the number that comes up on the screen. A direct line to support.
    superdutyfan, Speed_Drums and cke Thank this.
  10. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
  11. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    Center of the load between the king pin and the center of the trailer axles and you will be good.
    cke and Landincoldfire Thank this.
