Pitman Arm teeth wear
Discussion in 'Ask An Owner Operator' started by MTMAUS, Jan 30, 2026.
  1. MTMAUS
    MTMAUS Light Load Member
    258
    217
    Sep 28, 2019
    I posted a while ago about some bad tyre wear, well I finally got to take the truck for a trip (driver has been in it)
    And you can't keep this truck straight lol, I think driver was just used to it.
    I think the teeth on the Pitman Arm are probably worn out. Not sure if that's what's causing the tyre wear, but the truck is certainly a pain to drive. It wonders all over the place
    My question is, what's the chances it the splines on the actual steering box that a worn? Which is more likely, the arm itself, or the steering box?
    If it is the splines on the steering box, can that be replaced or is it a new steering box needed?
    I would probably have a crack at just replacing the arm myself, but if it's a full steering box, will leave it to the mechanic.
    Thanks
  3. brelin388
    brelin388 Bobtail Member
    28
    38
    Oct 15, 2025
    Start by swapping the Pitman Arm, that’s usually the culprit. Steering box splines rarely wear unless mileage is insane.
    Big Road Skateboard Thanks this.
  4. MTMAUS
    258
    217
    Sep 28, 2019
    Thanks, I am guessing 1.2million miles doesn't count as "insane mileage"
  5. D.Tibbitt
    157,108
    MTMAUS Thanks this.
  6. Diesel Dave
    9,654
    32,701
    Jan 20, 2010
    Hesperia, Ca.
    Before you start replacing anything, I would get someone to help you by getting in the truck and rocking the steering wheel side to side quickly like they do during inspections and you can be looking at the ball joints, pitman arm and steering column to see what’s loose. Just my opinion.
    Oldman83, D.Tibbitt, The_vett and 3 others Thank this.
  7. rollin coal
    rollin coal Road Train Member
    13,617
    27,993
    Mar 29, 2008
    TN
    Just grab the steering shaft and twist it back and forth you'll be able to see pitman arm play on the shaft it's obvious.
  8. Big Road Skateboard
    7,096
    40,270
    May 2, 2021
    More likely the pittman arm than the shaft. I've never seen splines on the shaft damaged unless a well worn arm was left too long.
    But if you're having tire wear issues, it's probably not coming from there, though it can definitely cause driveability issues.
    As @rollin coal said, you can see it move pretty easily.
    Diesel Dave, D.Tibbitt and The_vett Thank this.
  9. MAMservices
    MAMservices Medium Load Member
    596
    4,385
    Aug 9, 2021
    Splines on pitman arm or steering gear will not wear regardless of mileage unless the arm has been run loose.
