Placard question
Discussion in 'Hazmat Trucking Forum' started by Air Cooled, Jun 30, 2020.
  1. Air Cooled
    Air Cooled Road Train Member
    1,315
    1,094
    Jul 17, 2011
    Baltimore
    i believe I know the answer to this but I’d like to hear some expert opinions.
    Tomorrow I’ll have my usual flammable and non flammable placards as I’m a cylinder hauler. I will also be displaying an inhalation hazard placard as I will he hauling chlorine which has a RQ of 10 lbs and requires a placard.
    I will finally have over 1,001 lbs of acid in 55 gallon drums. I know this requires a fourth placard displaying corrosive.
    At which point do these labels require the UN number. In particular the inhalation hazard and corrosive material?
    truckdriver31 Thanks this.
  3. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    whats the orange book tell you
    alds Thanks this.
  4. Air Cooled
    1,315
    1,094
    Jul 17, 2011
    Baltimore
    I believe that a larger quantity of these gases IE in a tanker would require a UN number as its in bulk. This mostly doesn’t apply to my daily functions but I’d like to know out of curiosity and to get a better understanding.
    The JJ Keller books and FMSCA is basically like interpreting Chinese
  5. Ridgeline
    22,723
    123,063
    What he said.
  6. wis bang
    wis bang Road Train Member
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    Corrosive, that amount doesn't require the UN 1830 corrosive.
  7. MACK E-6
    49,989
    237,914
    The UN number is required for shipments in bulk packaging, or for more than 8800 or so pounds of the same product on the truck with nothing else on board.
    Shipments requiring display of the number due to bulk packaging are not to be counted toward your aggregate total for placard requirements.
    Air Cooled and gentleroger Thank this.
  8. WillisReid
    WillisReid Bobtail Member
    FWIW Reportable quantities have nothing to do with placard requirements.
  9. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    I was lokig for that weight information for quite some time. The latest TDG (Canadian book) doesn't say anything about it anymore.
    A shipper recently mentioned 8820 pounds. I think it may compare to 4000kg.
  10. wis bang
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    When they started making non tank vehicles display the 4 digit UN/NA number is was any HM over 8000# loaded from the same shipper needed to be identified by the number on the appropriate hazard class placard.
    kemosabi49 Thanks this.
