Planning for future O/O
Discussion in 'Ask An Owner Operator' started by Eaton18, Nov 20, 2011.
  1. Eaton18
    Eaton18 Road Train Member
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    Ok, I know and have been reading through the numerous posts, threads concerning becoming an O/O, which is worth more than any of these Mills charge for tuition. I have one question that I haven't been able to find an answer to yet.
    I'll be starting my career within the next week or so, driving for a small family company pulling an end-dump. They pay percentage, not CPM. What I want to do, from the start, is to start figuring and saving towards purchasing my own rig. I've read the break downs, based on CPM, ie; .02 for maintenance. I'm setting up a spreadsheet, to track the number of miles I drive, the weight of the product, and then what it pays. Would this be a somewhat accurate way to produce some numbers on what I need to be setting aside?
    For example if the truck is paid $1,000, I just use the miles I hauled it to determine a figure for the CPM? I'm thinking that carriers may reduce the pay by some amount, then pay a percentage of that, or use that reduced figure to pay a CMP.
    I'll be training, by follow-the-leader, with an O/O leased on to this company. So I know I can get the actual numbers on what the shipper is paying, and where to look for it on the BOL.
    I'm new to this whole thing, but I want to start from the get-go on looking towards owning my own rig, tractor and trailer. I may be nuts, but I think doing this from the start, I may stand a better chance of achieving it.
  3. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    There are 100 ways to skin this cat but sounds like you are getting a good start. If from the start you are tracking all this you will be able to go back and plug in numbers that work for you.
    At this stage, setting a firm CPM on anything is premature. Because until you have an idea of the truck you are going to buy, what you are going to be pulling, etc; it is meaningless.
    For example, end-dumps will take you into areas that are harder on a truck. So you will have increased maintanance, fuel consumption and less miles. Compare that to pulling a reefer with more miles, few rough roads, etc and your numbers are going to be wildly different.
    volvodriver01 Thanks this.
  4. jmcclelland2004
    jmcclelland2004 Light Load Member
    204
    91
    May 22, 2011
    Modesto, Ca
    Just to add to what Bill is saying a small flaw in your plan is in knowing what you are going to do. As he said end dumps tend to have higher maintenance because of the roads they travel. Another key is the fact that most of those types of runs pay by the load or by the weight not necessarily the miles, in the OTR industry it is more common to be paid by the mile. While your plan is good and will give you a lot of good baseline numbers don't forget to adjust them based on the type of freight you get into. Also keep in mind that older tractors tend to need more maintenance, as well as when you buy a used truck the better the deal the more you are likely to spend to get that truck back in working order. This I learned from experience we spent right at 17k for our truck and trailer and even after having them checked out have managed to put about 10k into them in little things here and there. Even still there are things that don't work that we have deemed as unnecessary such as the bunk A/C, the upper bunk lights and a few other minor things like that.
  5. Eaton18
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    Thanks for both your replies. What I would probably do is continue with the same company. They haul salts from the Lyons / Hutchinson KS mines, along with rock, flyash, potash, ect.
    The driver that will be training me, has been leased on to this same company for 19 yrs now. He seems to be doing quite well. He runs a real nice Pete 379 and his own end-dump trailer. He's a real good friend of mine, known him for a very long time.
    While it's way too premature to know exactly what truck/trailer I want, I do however know that if at all possible it will be a Pete, either 379 or 389, 13spd. I'll have to see what make/model of trailer they're using, how they handle.
    I guess what I'm more interested in now, is a way to figure out, if possible, what the CPM would be if being paid on percentage. Is there an accurate way to determine that?
  6. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    You don't even know if you will enjoy the job yet... put your dreams on hold until you get a taste of what it's like...
  7. DragonTamerBrat
    DragonTamerBrat Road Train Member
    2,742
    985
    Jun 6, 2011
    Easy equation: Money you made / miles you drove
    EX: $200/2000 miles = $0.10/mile or 10 cents per mile. If you take a job that pays that little, you deserve what you get, it is JUST an example w/ easy numbers.
  8. jmcclelland2004
    204
    91
    May 22, 2011
    Modesto, Ca
    Not to be a ######## but I'm pretty sure that would be $1 per mile. I'm assuming its a typo though so o-well.
  9. DragonTamerBrat
    2,742
    985
    Jun 6, 2011
  10. Eaton18
    1,755
    1,104
    Sep 3, 2011
    Waverly, KS
    I'm not in a hurry, though it may sound like it. I just was thinking why not start running some numbers from the start. I wouldn't entertain going O/O without having at least 2yrs driving. Will I like it? You're right can't make any sound decision on that yet. However I have one advantage going into this, something that most all you don't. The guy that's training me, trained me as a deputy years ago. He's an O/O, been leased onto this company for about 20yrs now. To you that may not mean much, but this is a man that I trust with my life, have had to. He's the type that if things are a little iffy, not going as he likes, he takes his toys and goes home. For him to stick with them for that long, something's got to be right about it.
    I'll be pulling end-dumps, for a small mom/pop operation (55 trucks). They also have pneumatics. It's not skateboards, what I wanted, but we all have to start somewhere.
    That's what I was thinking, but since it's percentage, any deadhead miles is not paid so to speak, It may be figured into the percentage somehow, but I doubt it. So I just ignore any deadhead miles? I'll be running about 50-100 deadhead miles a day. I'm not sure if I'm explaining of where my question is, should or should not be. I think to arrive at some accurate figures, I would somehow have to account for those miles too, where with percentage pay, they're not part of the equation.
    Heck, I probably will not be out all week for a couple of weeks, I know the guy training me is home almost every night, so I'll have to follow his routine until I'm finished with training.
  11. rollin coal
    rollin coal Road Train Member
    13,633
    28,021
    Mar 29, 2008
    TN
    They (deadhead miles) are a part of the equation. You divide all miles into your gross pay to figure what you made per mile regardless if you're paid percentage or mileage.
    Eaton18 Thanks this.
