please help: Airbag won't go up when hook up heavy load
Discussion in 'Volvo Forum' started by khouan, Dec 14, 2013.
  1. khouan
    khouan Bobtail Member
    hi,
    I have 04 Volvo vnl, the problem is when I I hook up empty trailer or ride with no trailer, the air bag level is fine, but when I hook up heavy loaded trailer the airbag wont go up, it look like there is no air go to the airbag at all, if I drive it , it will shake and make noise , sound like transmission going to fall off,so I change the air leveler and it take care of that problem for a month and it happen again, so I buy another new air leveler and put it in again this time wont do any thing at all, if u have that problem before and know what cause the problem please help, and sorry for my bad English...
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Leak going to your airbags or the airbags are leaking. Had this problem in an 01 Classic recently. Didnt find the problem until we sprayed the airbags with soapy water, all 4 were covered in tiny leaks.
  4. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    Probably from water in the system and staying in there.
  5. andre
    andre Medium Load Member
    341
    172
    Feb 10, 2008
    Jacksonville, FL
    Does the airbag hold air when the truck is off? If it does not, how fast does the airbag lose its air when you shut the truck off?
  6. snowwy
    snowwy Road Train Member
    20,618
    13,340
    Jul 6, 2009
    this time of year. it's possible a line is frozen to the airbag system.
    my t660 won't hold air when it's too cold and shut down. has no problem in warmer climates.
  7. boneebone
    boneebone Road Train Member
    2,297
    2,373
    Mar 13, 2009
    It seems like it's a defective Air Leveler, if you installed a new one and it solved the problem and it happened again it is most likely defective.
  8. Losthyway
    Losthyway Bobtail Member
    9
    5
    Apr 30, 2013
    Like Keith Saud. Get soapy water or glass cleaner and spray air bags and lines to and from valve. Must be a leak somewhere.
  9. BuzzardTrkr
    BuzzardTrkr Bobtail Member
    20
    9
    Nov 19, 2013
    Dallas, TX
    I have been looking for somewhere to post this, and this is as good as any. My trailer is leaking from a valve mounted on the reservoir. If my trailer supply is off, air pressure builds fine. When I supply air to the trailer, the valve on the trailer leaks air at about 50 PSI. It's got 4 hoses into it, going to various parts of the axle on the trailer. The little black "cap" in the center has a screw through it. That's what leaks. Can I adjust it or wait for repair? kind of in the middle of nowhere.
  10. Ridgeline
    22,778
    124,634
    I don't know if Volvo uses the electronic leveling system like some freightliners do. I had one on a truck and had it removed because it was a nightmare for the driver.
  11. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Can't adjust as it's just an exhaust port, check the brake pots because one of them is probably feeding back through. Spring or diaphragm probably gone.
