please help. loud grinding noise going down the road
Discussion in 'Trucks [ Eighteen Wheelers ]' started by welttruck, Nov 7, 2012.
Page 2 of 5
Transmission
Hi did you figure out what was making tht noise in ur truck a while ago .? got same prop and I cant find the answer... let me know I try to fix it for past few months thx reply to ijpierscionek@gmail.com best regards
dztruck Thanks this. -
my truck has this same issue. all symptoms buddy is having is the same problems I'm experiencing. it does stop when taken out of gear
can someone please help me with this problem??
I had same type of problem as the O/P described. I couldn't find it, so I kept driving it. After a couple months where the input shaft goes it to the power divider it started to leak oil right behind the yoke.
Took it to the shop to have a new seal put in and was told that the bearing on the input shaft was bad.
I had the power divider rebuilt and no more noise. -
How much did that cost ya to get fixed?
It was 4500 CDN Last year. I could have done just that front bearing but it had over a million miles so I did the complete rebuild.
Marsh92 Thanks this. -
and this power divider issue would cause me to have a weird grinding noise mostly on flat ground and on downhill grades over 60mph? it happens for 2 to 5 seconds and stops and just keeps repeating..
That's the exact way mine was acting
Not saying 100% yours is the power divider . I had every U joint and stuff checked and couldn't find anything.
So I just kept running it. Until it became more apparent. Drive line noises could be many things and untill you pull something down to look at it it's hard to find sometimes.Snailexpress Thanks this.
Page 2 of 5
