please help. loud grinding noise going down the road
Discussion in 'Trucks [ Eighteen Wheelers ]' started by welttruck, Nov 7, 2012.
  1. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Power divider or pilot bearing
    Roborope Thanks this.
  3. DechkoTzar
    DechkoTzar Light Load Member
    70
    28
    Apr 26, 2015
    I get the grinding noise in certain gears, mostly 6, 8 and 10th (10 speed manual eaton transmission) when going UP the hill. The Volvo dealership in Des Plaines, IL said that it was a synchro and they have changed it but the noise is still there.
    I have noticed that the driveline shaft is shaking during the uphill driving. Any thoughts?
  4. Marsh92
    Marsh92 Bobtail Member
    6
    Mar 16, 2016
    yea it's your ride height guaranteed..... back is probably lower than factory setting... trust me.
    6wheeler Thanks this.
  5. meho salic
    meho salic Bobtail Member
    12
    I'm having the same issues. Had my driveline shaft shaking got it replaced not shaking anymore. Also, heard it scraping noise. How could I check the height to make it factory setting? Also, what do I need to replace?
  6. Mikipatiki
    Mikipatiki Bobtail Member
    [GALLERY=][GALLERY=][GALLERY=][/GALLERY][/GALLERY][/GALLERY]
    I have internationl prostar 2009, similar noise was appearing on my truck, my was when I'm driving over 50-65 mph but was appearing exactly when I was on flat surface or downhill most likely when I take of my feet of the accelerator will appear for 2-5 sec and was gone for 2-5 sec, if I was using the eng break while going downhill or flat surface will not appear the noice.... The problem was the airleavening valve of the airbag on the drive wheels, in my case the metal stick somehow come out or disconect from the airleavening valve which is mean that I was driving whit out air begs... Frind of mine told me; if the gear box and the shaft is not in right position or angel will start making this noise or grinding. What I have to to was only put back the metal stick to the airleavening valve.. Thanks to my frind I didn't have to towing my truck or bring to mechanical shop.
  7. Sleepy5206
    Sleepy5206 Bobtail Member
    Hey did you ever find out what the grinding noise was?Mine doing the same thing. Please let me know.
  8. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I had the same problem. Air level value was over inflating the airbags.
  9. sbaumann14
    sbaumann14 Road Train Member
    1,243
    1,445
    Sep 1, 2010
    Rhinelander, WI
    what I did on mine, was get a metal rod same thickness as original one from Menards, Home Depot...ect. And get 4 small hose clamps. Cut the original rod, and add a 1 foot section of new rod. Secure with 2 hose clamps on top, 2 on bottom. Now you have a slider bar and can adjust up or down as needed.
    Singhfreightliner07 Thanks this.
  10. VolvoPower
    VolvoPower Bobtail Member
    May 16, 2018
    Did you find what the problem was?
    I have the same problem, only in 13 speed around 60-64 when i use just a lil bit of power on the fuel pedal
    I went underneath the truck and did not notice any leak from the transmition
    Yesterday i had problem with the air leveling valve and the airbags were deflated
    After i got it replaced i noticed just a lil bit of grinding with the valve replaced
    The noise was extremely loud when the valve went off and the airbags deflated, now its quieter but still is there
  11. Arkansas
    Arkansas Medium Load Member
    514
    669
    Dec 20, 2014
    LA- Lower Arkansas
    Check your air bags
    VolvoPower Thanks this.
