PLEASE HELP - My automatic transmission truck wont go into gear
Discussion in 'Peterbilt Forum' started by sprechnd, Apr 5, 2014.
  1. Infidelity
    Infidelity Bobtail Member
    My 2009 kenilworth will not start.It has a EATON 18 automatic with a c13 cat
  3. QUALITYTRUCK
    1,823
    1,793
    Jun 14, 2009
    romulus,mi
  4. Truckers Report Jobs
  5. 7seriestv
    7seriestv Light Load Member
    230
    145
    Jan 28, 2016
    Did you turn it off in gear? Disconnect the battery cables about 15 minutes so the transmission can reset and try it again
    2013Maxx Thanks this.
  6. Prostar 888
    Prostar 888 Bobtail Member
    Sir i have international prostar 09 cummins isx its flashing f and N gen trans fault wont crank,i have clutch pedal on my truck I'm suspecting its the clutch but im not shure why is not cranking if you have any experience with this please let me know god bless you and thank you for your time.
  7. QUALITYTRUCK
    1,823
    1,793
    Jun 14, 2009
    romulus,mi
    "F" indicates that there is a transmisson fault active in the TCM. Could be any number of things faulting which in turn will not let engine start. Need to plug in with Eaton service ranger software to find solution.
  8. Khurramamna
    Khurramamna Bobtail Member
    2017 Kenworth t680 cummins isx having a humming noise coming fro driver floor
  9. Pete Bilt
    Pete Bilt Bobtail Member
  10. AdriaanNam
    AdriaanNam Bobtail Member
    I have a eaton transmission that keeps on staying in N and then later flashes N,F if you select drive it goes into gear but then immediately goes back to N could this be a voltage problem or is ECU broken
  11. Todd727
    Todd727 Medium Load Member
    300
    584
    Jun 7, 2021
    Had a similar issue on an Allison. New alternator fixed it.
  12. Chris337
    Chris337 Bobtail Member
    What was the problem if u don’t mind me asking bc mine has been doing that for the last few months every blue moon
