PLEASE HELP - My automatic transmission truck wont go into gear
Discussion in 'Peterbilt Forum' started by sprechnd, Apr 5, 2014.
  1. Truckher477497
    Truckher477497 Bobtail Member
    I have a 2007 Freightliner Century having a similar issue. (Smartshift)
    Hand computer code = Code SPN 161 Transmission input Shaft speed. / SPN0161 Occurrence count 5 / FMI=5 - Current Below Normal or Open Circuit
    (I believe it's the open circuit because the dash code says "Trans In Shaft SPEED OPEN 130 161 05 N/F*” (*flashing between both)
    I recently had a friend install an inverter. Shortly after my check trans light began to flash. Thought maybe I needed new Batteries because I just bought the truck a few months prior, so I bought 4 new.
    It worked for a quick sec then Flashing check trans light and codes again, also heard a grinding sound as I was stopping to check, I stopped almost immediately after hearing the sound. Thought it might be out of trans fluid but when checked it wasn't the true.
    Currently: won't shift into gear anymore.
    I tried disconnecting from the battery. When I was stranded out of state I disconnected while I was sleeping, woke and it got me back home only to stop shifting into gear 3 blocks away from home.
    Now parked down the way and can't get it out of gear. Tried the battery trick again for a few days this time. No go. Still flashing F/N and throwing codes above.
  3. Todd727
    Todd727 Medium Load Member
    300
    583
    Jun 7, 2021
    Did you or can you disable the inverter? Allison's do not like low voltage and if the inverter is placing too much of a drain on the alternator, it is going to cause problems in my experience. There may be a possibility that the installation has an issue too.
  4. Truckers Report Jobs
  5. Truckher477497
    I need help with a similar issue:
    I have a 2007 Freightliner century class Eaton fuller ultra shift.
    wasn’t switching gears.
    I was getting dash code:
    Trans in SHAFT SpPEED OPEN 130 161 05 and flashing F & N
    handheld code: SPN 161 and FMI = 5
    So far
    Replaced the shaft speed sensor and the XY shifter
    codes cleared but same issues it won’t go into drive and now flashing 2 with a down arrow ⬇️
    can anyone help?
  6. Truckher477497
    I disconnected the inverter a while ago still no go. Called a shop and they say the EF trans are pretty sturdy so I should do more troubleshooting before assuming it’s dead. I am in a bind. Any suggestions after replacing drive shaft sensor and the XY shifter????
    no more codes but flashes 2 with down arrow now. Still won’t go into gear
