please help. truck wont go into gear
Discussion in 'International Forum' started by kenworthcanuck, Aug 14, 2014.
  1. kenworthcanuck
    kenworthcanuck Bobtail Member
    16
    Jun 17, 2010
    We just bought an 2012 international prostar about two months ago. It spent almost a month in dealer for warranty work and have replaced the injectors and the injector wiring harness due to a short. At the time we did the work on the injectors it was having trouble shifting. It is a 13 spd ultrashift.
    They claimed that the shifting problem was due to a failure with the injectors and was working fine after the "fix".
    Now it has more problems. On the way back from its last trip the yellow triangle warning light came on along with the fault code "gen trans flt". It would not upshift until the driver disabled the anti rollback switch. Everything went back to normal for a few hrs and happened again.
    Now the truck will not go into 1st at all. Flashes N then F and beeps whenever trying to put into gear. ABS module code electrical fault code started flashing as well. As well as the numbers 88 and 27 Where the gear number would normally display.
    Have tried disconnecting batteries top of transmission fluid checked as many grounds as we could find.
    Any ideas ? Am broken down currently and have no one open at the moment to call.
  3. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    I don't know if this help. I have a 2006 9400 ultra shift , I had the same problem a couple of weeks ago. My truck would not go into gear. I had the speed sensor replaced, it fixed problem.... Cost $883
    Puppage Thanks this.
  4. boneebone
    boneebone Road Train Member
    2,298
    2,373
    Mar 13, 2009
    and that folks is why you stick with a Manual Transmission when you buy a truck. Good Luck.
    SHO-TYME, "semi" retired and jbatmick Thank this.
  5. 201
    201 Road Train Member
    12,950
    26,686
    Apr 16, 2014
    high plains colorado
    Hi boneebone, I was thinking the same thing. Like most of today's modern gadgets, they're fine when they work, but when they don't, heaven help you. I've always thought these complicated systems in trucks was just an excuse to make sure regular Joes can't fix them and to keep their mechanics working. Due to the people that can't shift a truck now, more and more trucks will have automatics, and these problems will become the norm. So sad.:biggrin_25512:
  6. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,160
    Mar 9, 2014
    In a van down by the River.
    Can u flip it to manual and shift it? I have 10 speed ultra shift and mine lets me alternate back and forth
  7. Heavyd
    Heavyd Road Train Member
    7,836
    6,289
    Feb 4, 2009
    If you are getting the ABS module fault coming up there may issues with the datalink between the Trans and ABS and Engine.
