Please help with batteries dying.
Discussion in 'Questions From New Drivers' started by Apnightsky, May 4, 2024.
  1. Apnightsky
    Apnightsky Bobtail Member
    15
    9
    Feb 7, 2024
    I ha e a dometic fridge cfx 75 and cfx 45 also they have their frieghtliner fridge running. It's a piece of #### and doesn't get cold. If my batteries are good should this cause truck to die when doing my 10?
    Loves said I have a bad battery pack but ####y company doesn't want to fix em. Blaming me for my equipment.
    77fib77 and Flat Earth Trucker Thank this.
  3. bryan21384
    bryan21384 Road Train Member
    15,742
    34,313
    Sep 18, 2009
    Memphis, TN
    If you had your batteries tested, and it's determined their bad, I'd not use the personal fridge, get back to the yard, and have them fix it in house. A reputable company would have no issues fixing it..the smaller ones want to do everything in house....they'll eat #### if you can't drive due to drained batteries.
  4. TripleSix
    133,428
    So, you cut the truck off for 10, then can’t start, correct? And when the truck doesn’t start, what do you do? Find someone with cables?
    Personally, I would idle the truck. Not playing the blame game. I wouldn’t say anything about any fridge, theirs or mine. FM. If the batteries are bad, you should begin to smell them. When that happens, expect them to swell and blow up. Just letting you know for when you hear the pop.
    77fib77, AModelCat and tscottme Thank this.
  5. tscottme
    tscottme Road Train Member
    Your truck batteries, at least one of them, are weak. Since you mentioned your fridge, the company wants to blame it rather than the batteries.
    Option 1: idle the truck so you don't need strong batteries until your company's shop can check/replace them.
    Option 2: unplug your fridge when you spend a 10 hours out of it or restart the truck during your 10.
  6. beastr123
    beastr123 Road Train Member
    2,951
    24,205
    Jan 2, 2014
    Moose Jaw SK CAN
    Start by shutting off the freightliner fridge, it is probably running constantly at 10 amps and will be draining 20% or more off the top. your #75 draws 8 amps while running and your #45 draws 8.5 amps while running. This is a stopgap until you get back to the yard and have your batteries load tested individually.
    blairandgretchen Thanks this.
  7. Apnightsky
    15
    9
    Feb 7, 2024
    Not my equipment for sure. Truck just died cause I forgot to hit engine off override. Treid starting it right away no luck. Also neg nuts where not tight at all. I've been in. Truck 2 months I told them month ago about batteries being bad. I just learned that could have ruined batteries. The poor connection.
  8. AModelCat
    164,828
    See what happens with the cables tight. You could easily have lost a volt or 2 because of that.
  9. Apnightsky
    15
    9
    Feb 7, 2024
    Truck still won't start even a second after turning it off after driving all day
  10. Apnightsky
    15
    9
    Feb 7, 2024
    Loose connections destroy batteries
  11. AModelCat
    164,828
    Depends. If you've discharged them too many times they'll be toast. Once or twice you can usually get away with it.
