Please make it make sense
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 85COE, Dec 9, 2022.
  1. 85COE
    85COE Light Load Member
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    85 Volvo COE
    New pump
    Lines are clear - tested with air from compressor. Air blows through
    Reservoir is full
    Will not spray fluid onto windshield
    3 shops are stumped
    austinmike and RubyEagle Thank this.
  3. Star Rider
    Star Rider Road Train Member
    1,814
    19,524
    Sep 23, 2019
    Is polarity reversed on the pump and running it backwards?
  4. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    Air lines are connected properly
    Oxbow Thanks this.
  5. Star Rider
    1,814
    19,524
    Sep 23, 2019
    The electric going to the washer pump. If the wires are hooked backwards the pump will run in reverse and flow the opposite the way it should.
    austinmike and Oxbow Thank this.
  6. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    I failed to.mention it is air-powered
    Old school truck
    Oxbow Thanks this.
  7. Star Rider
    1,814
    19,524
    Sep 23, 2019
    I think it would be easier and cheaper to just wire in an electric pump.
    jsnell, ducnut and Oxbow Thank this.
  8. RubyEagle
    RubyEagle Medium Load Member
    632
    790
    Apr 17, 2010
  9. 85COE
    242
    505
    Aug 6, 2019
    Columbus, Ohio
    You would be incorrect
    Brand new, and tested
  10. Oxbow
    Oxbow Road Train Member
    13,706
    142,302
    Nov 24, 2015
    Only thing that comes co my mind is vent in reservoir plugged, but you should see something prior to vacuum lock.
    singlescrewshaker Thanks this.
  11. singlescrewshaker
    4,933
    43,355
    Dec 31, 2017
    Little Havana, FL
    You got a new Sprauge control valve in the dash?
    I had one go bad where when I depressed it to spray fluid, air come out the weep hole in the bottom, instead of the line going to the reservoir.. Wipers still worked though..
    Flint1 Thanks this.
