Plugging tires? Yes/No?
Discussion in 'Experienced Truckers' Advice' started by Concorde, Jun 23, 2023.
  1. Concorde
    Concorde Road Train Member
    5,506
    19,594
    Jun 29, 2016
    West Melbourne Florida
    Looking for some advice on plugging tires..specifically trailer tires (van).
    I’ve never ever plugged a tire in my long life but I’m so sick of discarding perfectly good tread tires.
    Seems like every time I pick up a nail it’s on the outer edge of the tread and can’t be patched. Got one now that I started to pull while spraying the spot with soapy water..sure enough it’s a leaker! (Drove that nail right back in, lol)
    Just wanting to know if plugs are a decent solution at least temporarily for a few months. Last time I replaced one it was $650+ for one of the Bridgestone 123’s low pro.
    I don’t know if I just got bad luck with nails in tires or if I need to just stop looking at my tires 2-3 times a day :)
    My gut is telling me it’s a waste of time to plug them so figured I’d ask the forum since I have zero experience with them.
  3. Short Fuse EOD
    2,791
    8,762
    Jul 29, 2015
    Midwest
    If it’s on the tread I have loves do a repair. If it’s on the edge, I have Olson tire (Meekoff) retread it.
  4. Big Road Skateboard
    7,200
    40,878
    May 2, 2021
    Plugs work fine. My Christmas gifts for customers were always plug kits from Fleetpride.
    Saved them tons of money.
    I plugged 2 trailer tires on my old set, and wouldn't think twice of plugging a drive either.
  5. Concorde
    5,506
    19,594
    Jun 29, 2016
    Never had a tire retread done before..what’s a normal charge to have them done?
  6. Concorde
    5,506
    19,594
    Jun 29, 2016
    Thanks, my second question was going to be what kit to buy..I’ll look into Fleetpride now.
    Rideandrepair Thanks this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Personally I used plugs so I could finish my load. Then I took it to a tire shop for a proper repair.
    I know lots of guys that just used the plugs and never bothered getting it fixed in a shop and they didn’t seem to have any problems.
  8. Short Fuse EOD
    2,791
    8,762
    Jul 29, 2015
    Midwest
    They do a in-house mold to fit my carcass for 180. Kind of like a mini tire factory at their shop. I trust their recap jobs, bout everyone else that runs multi axle trailers in Michigan.
  9. W923
    W923 Road Train Member
    1,426
    4,419
    Feb 28, 2022
    Just patch it from the inside and move on…unless you’re one who doesn’t understand how to properly check tire pressure then the extra flexing will probably cause trouble
  10. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    Probably plugged about 40 tires, never once had an issue. Just don’t get cheap plugs, also don’t forget rubber cement and a drill
  11. bryan21384
    bryan21384 Road Train Member
    15,796
    34,424
    Sep 18, 2009
    Memphis, TN
    Plugs are great!!! They will extend the life of your tires greatly. If they get plugged too many times, they can't be recapped, but I don't know how times it can be plugged before it has to be discarded. I got one plugged at the terminal earlier this week. I even got one plugged in my personal vehicle. I'm hoping that holds serve at least til next spring when I can replace those tires.
