Pndb western star
Discussion in 'Ask An Owner Operator' started by Westernstar321, Apr 23, 2023.
  1. Westernstar321
    Westernstar321 Bobtail Member
    6
    Aug 1, 2022
    I have power coming into my Pndb but none coming out. Red light flashing. I put a jumper on and everything works. Been searching for a new Pndb and see some on eBay with different part numbers but look exactly like the one on my truck. Has anyone used one with different part number?
  3. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    Check the fuses in the pndb before putting out that much money.
  4. Gridaxe5588
    Gridaxe5588 Light Load Member
    126
    168
    Nov 23, 2022
    I replaced the one on my Cascadia with one from eBay with different part number, I just made sure everything on the box matched what was on mine and it worked perfectly.
  5. Westernstar321
    6
    Aug 1, 2022
    Thanks, I checked all fuses and they are good. Here in Canada the last Pndb I bought cost $644 plus tax. I don’t understand why the difference part numbers and the part has same fuses and the 2 plugs one for cutoff switch. My part number is A66-03714-002. I think I’ll try a new one from eBay that has same fuses and the 2 plugs
  6. Gridaxe5588
    126
    168
    Nov 23, 2022
    Got mine on eBay for like $130 shipped, it was a new OEM in the box labeled from Mexico, so it's not a knock off aftermarket.
  7. Westernstar321
    6
    Aug 1, 2022
    Did it have the same part number or did you just get one that looked the same. I don’t know why they have different numbers
  8. Gridaxe5588
    126
    168
    Nov 23, 2022
    Different part number, I made sure what mine said on the cover matched what was on the cover of the different part number.
    Westernstar321 Thanks this.
  9. Westernstar321
    6
    Aug 1, 2022
    Thanks, that’s exactly what I’ll do
  10. Gridaxe5588
    126
    168
    Nov 23, 2022
    No problem, I had the same question as you and could never get a definitive answer on here so I just went ahead and got one
