Polishing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ChipHaulinFLD, Jun 9, 2016.
  1. ChipHaulinFLD
    ChipHaulinFLD Bobtail Member
    12
    9
    May 19, 2016
    Sharptown, MD
    Ok so I've been working on my rig for the past couple months now trying to get that mirror finish on all my chrome/aluminum. Ya know wheels, straights, bumper, mirrors, etc.... I'm getting a decent shine out of the polish I'm using (I'll post pics) but I got some oxidation on the steers and this mess will just not take it off. So couple questions. I'm going to switch my polish this weekend.
    1. Any tips?
    2. Speedy or Zephyr Pro 40? IMG_20160607_170124335.jpg IMG_20160608_153317684.jpg [ IMG_20160520_144113388.jpg
  3. Derailed
    Derailed Road Train Member
    2,384
    2,657
    Dec 10, 2008
    Upstate NY
    Looks nice in the pics. If you really want to get that mirror shine I would pull the wheels off and start with a 400 grit sand than repeat with 800. It's the only way i have found you'll get the oxidation out.
    Jerzey, mitmaks and rollin coal Thank this.
  4. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I would try flashing them with brightener. That should get rid of the oxidation and calcium chloride film. It will not remove any pits. 400 grit is pretty light so it probably will do the same job. Nice truck, even nicer to see someone taking pride in their ride.
    rollin coal and bzinger Thank this.
  5. BigPerm
    BigPerm Medium Load Member
    After polishing, use a rag & cornstarch to remove the black residue. No rubbing, couple of wipes, yer done. Shake out rag...repeat.
  6. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    Admiral, aluminum brightener will take the oxidation away, a lot. Please tell me where it's available? Thx, J
  7. upallnite
    upallnite Light Load Member
    165
    115
    May 15, 2010
    Hempstead,TX
    get a load to Houston, we got a shop down here that will take your wheels off, remove the tires and put the rims on a machine that will buff and polish to a like new finish and remount everything for 75$ a piece. might be a little pricey but will give you a great starting point. easier to maintain.
    ChipHaulinFLD Thanks this.
  8. 062
    062 Road Train Member
    6,351
    34,032
    Oct 20, 2013
    @Starboyjim Napa or most boating supply stores will have brightener
  9. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    I wouldn't screw with brightener, get yourself a good (I use a milwakee) 6000 rpm grinder zypher wheels and rouge bars and buff them dirty process but it's a lot faster than anything else I have done. I can buff a wheel on the steer to the same shine you have from a completely oxidized wheel in a about 5 minutes and that's using a heavy cutting bar.
    When it comes to polishing there's a few things to remember sanding isn't necessarily for removing oxidation, it's to remove the pitting to get a smooth surface. Most start with 120 and work to 320 then buff. I start with 240 and go all the way to 1200 before I even think about picking up the grinder to start cutting.
    there's many polishes out there most are abrasive which is why you take them off with a microfiber towel I use pro40 seems to work well and it seems to be quick I use an air sander to apply it with a wool bonnet and take it off with a clean bonnet. I've polished my truck for a long time and it's due again but I dread it every time I buff it. Start to finish is from about 6 am to 9 but it looks better than half the polishing shops do around here.
    I'm picky when it comes to my truck, I want it done right, you can do coloring as well I don't, I don't really ever see that much difference between the final finish and using the blue moon coloring bar to mine.
    Only issue one has to worry about is valve stems on wheels and if the truck has chicken lights remove the wiring prior to polishing or drop the tanks completely off the truck and polish them on saw horses. I made the mistake of tying the wiring up one day wasn't paying attention and caught a loop ripped a 70 inch section of harness out, by the time the grinder stopped I had about 15 welts on my arms, and I've still got the scar from the gash the wire left probably still have a couple strands of wire in my arm as well.
    Never had a problem since as I simply remove the harness but I also am picky with wiring and all my harnesses are quick connect (weather packed now aside from the fender guards and bumper which I need to rewire)
    Oh and remember looking cool ain't cheap and looking cheap ain't cool...the wheels rouge and polish don't come at a cheap price I've probably got $400 wrapped up just in polish, bars, and wheels.
  10. bzinger
    bzinger Road Train Member
    16,659
    66,217
    Dec 10, 2014
    omaha , ne
  11. bzinger
    16,659
    66,217
    Dec 10, 2014
    omaha , ne
    Well get on up here I'm starting on my truck this weekend lol...nice looking truck op !
    379exhd Thanks this.
