Poor def quality?
Discussion in 'Volvo Forum' started by Roman78, May 29, 2021.
  1. Roman78
    Roman78 Light Load Member
    74
    27
    May 20, 2021
    What this code mean guys. How to fix t. Thanks for your help.
  3. Arctic_fox
    4,521
    25,589
    Sep 16, 2016
    Welp grab onto your ankles and ask the shop to use lube because your in for a world of hurt and trouble is what it means. Could be one of a number of things or a symptom of a dozen others. Best case is you got some crap def and draining your tank and refilling or putting in some good def will fix it. Worst case is a wild goose chase fixing a cascade failure of crap.
    Start with the cheap options. Drain and replace. If it doesnt clear up its likely a sensor has gone bad. 1# culprit is the quality sensor in the tank. #2 is one or both NoX sensors. #3 is the def doser could be acting up. If you idle a lot or havent done it recently it could also be a clogged EGR. If none of the above....good luck hope it doesnt turn into a 55k repair job like my pete had to track down the issue.
    Roman78 and AModelCat Thank this.
  4. Dave124
    Dave124 Light Load Member
    87
    72
    Mar 11, 2019
    I used to get that code, soon after refilling the tank.
    I was told not to top the tank off (try to keep cramming the fluid in after the pump clicks off).
    Since I stopped doing that, I haven’t seen the code since.
