Poor receiving and transmission
Discussion in 'CB Radio Forum' started by Logan Spoo, Jun 9, 2018.
  1. Logan Spoo
    Logan Spoo Bobtail Member
    7
    Jun 14, 2015
    First off here’s what I have everything is 3 Year’s old
    Cobra 29 Ltd classic
    18 ft Wilson coax ran through passenger door
    Wilson t2000 mounted on factory mirror mount
    My range has gone down considerably in the last year I have noticed. I use to hear and receive a lot farther away. Also getting quite a bit of static feedback and having to turn the squelch and gain down. I hit quite a few low branches and noticed the top of my antenna is bent at about a 45 degree angle. Is this what’s causing my poor range? Do I need to just replace the whip with a new one? TIA
  3. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Could be dirty factory mount..Could be pinched coax..Could be bad connections between ant and coax and radio...
  4. Logan Spoo
    7
    Jun 14, 2015
    So the bend at the top of antenna wouldn’t hurt my situation any? The coax is shut in the door so pinched might also be an issue
  5. Tensleep440
    Tensleep440 Light Load Member
    113
    63
    Mar 29, 2018
    NE Corner of Texas
    Replace your coax, I’ve always replaced coax in a rig yearly despite the fact it “looked” okay. Call me OCD but I never trusted it after a year of service unless it was high quality coax. Even then, passing thru a vent window or door frame WILL eventually make for bad juju. Check the connections at the stud. Make sure it’s all clean. Keep in mind skip is picking up currently also.
  6. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    The fact your body is completely made out of plastic isn't helping the situation.
    A dipole is the only antenna that I was able to get working on that truck
    handlebar Thanks this.
  7. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    You should clean and shiny up all your ground points about every 6 months or so. It will make a difference.
    handlebar and rabbiporkchop Thank this.
  8. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    Kinda hard to do that in a T2000 without gutting the interior.
  9. Logan Spoo
    7
    Jun 14, 2015
    I think you misunderstood truck isn’t a Kenworth. The truck is Mack granite dump truck. Antenna is Wilson brand
    rabbiporkchop Thanks this.
  10. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    I guess I was mistaken and Mike had the right answer
  11. mike5511
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Do I win anything?????:p
