Portable Air Compressor for Truck Tires
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by MercySakesAlive, Nov 8, 2021.
  1. MercySakesAlive
    MercySakesAlive Light Load Member
    133
    74
    Aug 8, 2008
    seattle ,wa
    Can anyone recommend a good portable air compressor for truck tires? Thanks.
    truckdriver31 Thanks this.
  3. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    Most drivers I know use a hose that attaches to a glad hand and basically uses the existing truck's air compressor. Unsure why you'd need a stand alone air compressor for your truck tires.
    If you're a hot shot or similar I guess one might come in handy. Most 110 volt compressors will go to 125 psi. Some go to 150psi. I'm not familiar enough with 12 volt or gasoline powered ones to give any recommendation.
  4. Suspect Zero
    Suspect Zero Road Train Member
    2,544
    9,860
    Oct 10, 2016
    Brookfield, IL
    You have the best compressor there is atrached to the engine already. Buy an air hose the put a glad hand on one end.
  5. truckdriver31
    7,001
    8,366
    Sep 18, 2013
    go to habor freight. get you a rubber air hose and straight air chuck
    Diesel Dave Thanks this.
  6. MercySakesAlive
    133
    74
    Aug 8, 2008
    seattle ,wa
    this question was regarding for a straight truck no glad hands. thanks.
  7. skallagrime
    skallagrime Road Train Member
    3,855
    9,929
    Apr 10, 2012
    Indiana
    Put a standard air compressor quick connect fitting on the air tank (assuming air brake system)
  8. truckdriver31
    7,001
    8,366
    Sep 18, 2013
    you got a plug on the tank. make a quick connect and get hose
  9. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    all air tanks have multiple ports to thread in whatever you want. thread an air fitting in. unless your talking about a non air brake straight truck. then i would understand the portable air compressor thing
  10. Ridgeline
    22,840
    126,174
    Does it have air brakes?
    MercySakesAlive Thanks this.
  11. MercySakesAlive
    133
    74
    Aug 8, 2008
    seattle ,wa
    yes thanks everyone for the great ideas about hooking up to the air tank. will look into that next opportunity I have. much appreciated.
    JoeyJunk, MidWest_MacDaddy and Don379 Thank this.
