Anyone know how to fix this. Been doing it 3 hrs now. It's only a month old, I've hard reset it, factory reset it. Nothing![]()
POS garmin
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Wespipes, Feb 10, 2020.
Page 1 of 3
Dezl 780 . Not on the compatible list
Well, their support forum doesn't offer much help, but if you haven't already you can read over this.
I would also try moving it around and getting it away from your prepass and see if that helps any.Dieselboss, O.Henry and Wespipes Thank this. -
See if you can use your phone as a hot spot and connect the gps wifi to it. The signal usually goes off of cellphone towers. If that doesn't work you can try to reset it. You will need a small pin to do it.
I use both, GPS and Google Maps on a tablet, mounted to the dash. But a Truck specific GPS would be fantastic!
I use a nighthawk mobile router. So its connected to wifi
Have you tried the GPS provided by TTR? It’s called Hammer and it’s free. Worth a try.
Page 1 of 3
