Possible rebuild?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FREDthaCEO, Dec 1, 2025.
  1. FREDthaCEO
    FREDthaCEO Bobtail Member
    16
    Mar 6, 2021
    Good morning I have a NXS C15 acert with over 1 million miles I have excessive blowby and when I'm climbing up the hills It struggles under a load.. It looks like it has some oil leaking from the blowby tube and when I start it I see white smoke coming out of the stack.. my mechanic told me its time for a overhaul I just came here for a second opinion but I'm leaning towards and overhaul as well but if that is the case what is the preferred overhaul kit to get
  3. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    Need a few more specifics. You say it pulls down on hills under a load, how much of a load? How big of hills. What is your oil consumption? Coolant consumption? How does it start from cold? Warmed up? What is the mpg?
    Bean Jr. and FREDthaCEO Thank this.
  4. JB7
    JB7 Road Train Member
    1,029
    1,818
    Dec 13, 2022
    Laurel, MD
    "I have excessive blowby" Based on what, observing the tube? Did your mechanic take a reading?
    "when I start it I see white smoke coming out of the stack" This is normal for a diesel in cool/cold weather.
    Bean Jr. Thanks this.
  5. FREDthaCEO
    16
    Mar 6, 2021
    Hey thanks for your reply coolant consumption is good but after an oil change I will run for about two months and the oil pressure drops again when pulling any kind of load my truck struggles going up hill. I don’t have any issues with the cold start
  6. FREDthaCEO
    16
    Mar 6, 2021
    It was doing this in the summer
  7. wore out
    wore out Numbered Classic
    17,376
    215,866
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    White smoke is fuel that isn’t burnt. It has 3 normal causes.
    1. A small amount of coolant on top a cylinder
    2. Low compression in a cylinder
    3. A bad injector that is pissing fuel instead of spraying.
    On a CAT 1 is most common doesn’t mean that’s your problem. But at a million I can assure you the liners are low and it needs uppers for sure most likely lowers.
    The smoke out the blow by tube as well as oil is a sure sign it’s wore ### out
    Sons Hero, Arctic_fox and FREDthaCEO Thank this.
  8. Big Road Skateboard
    7,163
    40,581
    May 2, 2021
    Also normal when you have low compression.
    I think maybe a byproduct of something that causes low compression could cause white smoke and excessive blowby.
    But, I'm just a driver. I'd run it till you're losing a gallon every 2k miles.
    Bean Jr. and JB7 Thank this.
  9. Lazer
    1,850
    2,983
    Jan 22, 2017
    ‘At about 2 months, oil psi drops when pulling up a hill’.
    Approximately how many miles are on the oil at that time?
    Do you use the same brand/weight of oil at every oil change? Have you tried a different brand/weight of engine oil?
    What does ‘pulling down’ on hills mean to you? Does the engine drop 100 rpm? 200? 1000?
    Do you drop a gear? 2? 4? Years ago downshifting on hills was considered ‘normal’, nowadays it’s looked upon as a ‘burden’, ‘horrible’ ‘my god I have to do that?’
