Possible water in fuel.
Discussion in 'Experienced Truckers' Advice' started by crocky, May 18, 2018.
  1. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Call your dispatcher, and shop.
    Arrange to have a shop dump your entire tanks. Dispose of the fuel inside everything to the engine and back. Replace the filters, all of them. (They are contaminated with water)
    Water can destroy a large truck engine very easily. They do not compress at all and make a already high compression situation a bomb inside a Desiel. This is why most engineers vent and drain water prior to starting a desiel in the morning, especially the older ones that have this feature. But these are like ship engines, train engines etc.
    Your company will be documenting everything and then billing that truckstop that sold you that bad water in fuel. Chances are you wont be the only one with it and might be the first to let them know hey you have water in your fuel you are selling.
    If you are loaded, have a team or another driver come get it off you. Your tractor is not feeling well and needs work like right away.
    NCTru919 Thanks this.
  3. crocky
    crocky Road Train Member
    1,732
    1,578
    Jun 28, 2017
    Check my last post, the water in fuel warning I was getting were not legit. It seems to be something else and as result I was getting those warnings. The fuel ended up being ok.
  4. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    We had those from time to time on our trucks. I don't recall the service work on them. However a regular check on them indicates they do get worked on at least one time per yer.
    To the OP, I viewed your post with videos. Etc.
    Bad fuel pump would be another idea. I had a fuel pump go bad once when the O Ring seals went out inside of it turning my big rig into a 20 horse power lawn tractor unable to go much of anywhere. But that's another idea.
    Lepton1 and crocky Thank this.
  5. crocky
    1,732
    1,578
    Jun 28, 2017
    Yea, fuel pump is kinda the idea Im going with at this time. I guess maybe because the fuel filters were ready to be changed that maybe the computer thought it was water in tbe fuel for some reason.
  6. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    I will be reluctant to touch the fuel filters, they are like 100 dollars each to spin off and replace. There should be two or three or more in there next to the engine block behind your left steer. If the fuel itself is really bad, like GELLED or spoilt with gasoline oops... etc. Yea those filters need to go and new ones put on. (They have done their job protecting that precious engine which could run as high as 60000 dollars to fix or replace...)
    Other filters or seperators are designed to be changed when necessary. And should be regularly. In my time we even had oil seperators or spinners. I forget the exact situation with them.
    But as of today if it aint water, it's going to be your fuel pump. You need to be in a shop today asap to be looked at. Generally shes throwing codes and not feeling well. You might not get alot of miles today, but you would be a good driver who cares and love your rig.
  7. crocky
    1,732
    1,578
    Jun 28, 2017
    Yeah Im stuck with the weekend situation in Laredo, Tx. The closest dealer closed at 2pm today. Due to having a loaded trailer and needing it to be repowered, I had to stay at the truck stop, otherwise my truck and trailer would get locked in at the dealer until Monday..
    So now I have to hang out here till monday and sshouldn't have a trailer at that point so I think Ill be able to limp it down there bobtail with out a tow hopefully.
    x1Heavy Thanks this.
  8. snowwy
    snowwy Road Train Member
    20,620
    13,341
    Jul 6, 2009
    NM.
  9. Dave_in_AZ
    433,686
    I got a fiddy says it's 100% bad fuel filters / bad fuel water separator filter.
    My ISX will throw a code for clogged filters as well. Don't ask me how it knows that. Low pressure? No clue but it will.
    DD 15s are weird though when they get serviced. You can't do all the filters at once, or you do the oil, then the fuel, or not all the fuels at once ( you have more than one I think ), it's something like that.
  10. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Water-in-the-fuel is the fastest, easiest and cheapest diagnosis to make, and there's no uncertainty about the results.
    In order to do it myself, I always have a clear mason jar with me. I catch the first contents out of the fuel filter drain into that jar and observe. Any water will be at the bottom of that filter, and it will quickly appear at the bottom of that mason jar as a separate layer or bubble. I give it up to five minutes or so just to make sure.
    A fuel filter / water separation filter with a clear sight bowl will allow the water to be seen, but the jar is more clear than a muddy sight bowl.
    Water and oil don't mix, at least not for long, which makes it nice.
    NCTru919 and Lepton1 Thank this.
  11. Christhetrucker
    Christhetrucker Bobtail Member
    Nov 29, 2018
    I just had a thermo king tri pack installed and now i got water in fuel sign and warm engine every once in awhile
