Power CB Radios
Discussion in 'CB Radio Forum' started by platinum, Mar 10, 2011.
  1. platinum
    platinum Road Train Member
    1,718
    291
    Aug 18, 2010
    Fort Worth, Texas
    I have a friend who has a couple radios one base and one in his pov truck. He can talk to people all across the country.
    If I have a Cobra 25 LTD Classic do I only need a amp and better antenna to do the same? What will I need to be able to talk to drivers all across the country?
  3. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    EVEN a 100 watt amp will work skip quite well
    BTW .....
    I live across the bay just south of the LARGO city limit ......
    If you have a radio scanner receiver you can hear me on 147.550 sundays at 8pm.
    Also there will be a radio flea market in Tampa
    http://www.hamclub.org/
    And another in St.Pete in April 30th
    http://www.sparc-club.org/
    Bruce
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Skip needs to be rolling before you can even think about talking across Country for starters...Next thing would be your antenna..."Taller the better" ...And last would be Power. Of course using a Amp will help out tremendously. But if your antenna ain't right, no mater how much power you run, it wont be enough...
    Another thing to consider would be the channel you pick to try and talk cross country on when DX is rolling...Although it is possible to chat across country with someone on 19, it's not likely you'll be able to simply because of local traffic on the channel...Not impossible, just not likely...
    Channel 6 would be another channel which would be hard to make a contact on simply because of some of the people that hang out on that channel running Meg-a-Watt stations that even if they herd you out there, if your not one of their "Homies", their not going to give you the time of day...
    Now DX can be found on just about every channel on the radio when it's rolling, channels that are less crowded would be easier to make long distance contacts on...
    Just getting started I would listen in on channels that you hear stations fairly good that you know are in different States, and are not real crowed and when you hear someone, make note of his/or her call sign (handle or numbers) and try to get back with them by calling them by name (or their numbers) People if they hear their name being called are more likely to try and get back with ya!
  5. vureo
    vureo Bobtail Member
    12
    Mar 7, 2011
    Houston, TX
    Something else to think about is getting a radio with SSB (single side band) 36-40 USB and LSB especially 38 LSB are good stations to talk skip
  6. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    Yep SSB is the better mode.
