power from battery
Discussion in 'CB Radio Forum' started by blacklabel, Nov 21, 2011.
  1. blacklabel
    blacklabel Heavy Load Member
    870
    1,268
    Nov 6, 2011
    MO
    Just curious how many do this and what size wiire and fuse do yyou run??
    I just have a cobra 29 right now, will be getting something bigger later on.
    Thanks in advance.
  3. mike5511
    mike5511 Road Train Member
    3,157
    1,547
    May 15, 2011
    NW Arkansas
    At least 10 gauge. If you are planning a small amp in the future go up to 8 ga. 6ga will handle anything you are likely to ever use. 10 gauge is probably over kill for just a straight, legal CB, but it is the smallest I will use. If you are going to power a radio and a linear, you can also run two sets of smaller gauge wire instead of one larger gauge wire. I ran 6 gauge when I was running a tuned up Cobra 29 and a Texas Star 667. Never had any lack of power problems.
    blacklabel Thanks this.
  4. blacklabel
    870
    1,268
    Nov 6, 2011
    MO
  5. mike5511
    3,157
    1,547
    May 15, 2011
    NW Arkansas
    Yep, right near the battery. I think I had a 40 amp on my 6ga if I remember correctly, then the standard fuses on the radio and linear as well.
  6. blacklabel
    870
    1,268
    Nov 6, 2011
    MO
  7. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    Play it safe fuse both Pos & Neg sides near the battery.
  8. mike5511
    3,157
    1,547
    May 15, 2011
    NW Arkansas
    Yes you are correct! Very good advice!
