Power inverter noise
Discussion in 'CB Radio Forum' started by northernhopper, Apr 7, 2016.
  1. northernhopper
    northernhopper Light Load Member
    260
    367
    Mar 15, 2015
    isanti mn
    Any help? I run my power inverter full time to run my fridge. Problem is, i get interference n the cb because of this. Is there a filter or some other cure so i can keep my food cold and listen to everyone cuss at each other?
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Inline noise filter direct from battery to your CB, and a direct ground. Will also remove the alternator noise you hear. You could just toss in a quick inline but it wouldnt be as effective
    northernhopper Thanks this.
  4. northernhopper
    260
    367
    Mar 15, 2015
    isanti mn
    Wow. That sounds easy. Cb shop should have what i need? Just a filter on the power wire only? Thanks
  5. northernhopper
    260
    367
    Mar 15, 2015
    isanti mn
    Rereading your post..... youre saying bat to radio direct. Dont use the trucks wiring. Run wire for cb only. If i understand you correctly
  6. ExOTR
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Any CB shop can install a noise filter, or you can pick one up yourself for 25$ and run it yourself. I prefer direct connection, but you can also run off the standard truck wiring but you still have to hook the filter direct to batt if you want it to clean it up fully.
  7. northernhopper
    260
    367
    Mar 15, 2015
    isanti mn
    Cheap and easy. Thank you
  8. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    This is the solution to your problem but it costs ten times as much as your inverter.
  9. northernhopper
    260
    367
    Mar 15, 2015
    isanti mn
    I'll prob just spend the 25 bucks instead
    rabbiporkchop Thanks this.
  10. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
    That's what most people choose to do. I like to take the expensive route
  11. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Go to a outdoor shop like an rv world..Talk to them about inverters..Truck stop ones and most auto shops n such sell cheaply made inverters..Rv shops usually sell them that dont cause whats called dirty power..
