Power inverter problem.
Discussion in 'Questions From New Drivers' started by xzmpt, Nov 23, 2024.
  1. Numb
    Numb Crusty Curmudgeon
    4,371
    10,412
    Jan 30, 2012
    Charlotte, N.Carolina
    overheat means not enough air moving inside
    check the fan for lint.
    had one that got clogged with dust. just open it up and clean for good air circulation.
    over heat means no air
  3. Ridgeline
    22,771
    124,455
    It also means that the inverter is not designed right to handle induction loads. This is a common problem with either really cheap "pure" sinewave or most modified sinewave inverters.
    Numb Thanks this.
