Power inverter question
Discussion in 'Freightliner Forum' started by Godcreatednu, Jan 9, 2021.
  1. Godcreatednu
    Godcreatednu Bobtail Member
    9
    May 5, 2017
    Allentown, PA
    My cascadia came with a power inverter already installed (1200w)
    I can only use it for 2hr then it needs to wait 8hr to be able to use it again,
    Thats why i bought a new 2000w inverter
    I want to know
    If it is only a swap of cables to the new one?
    And can i do it without a kill switch because my truck dont have one?
  3. Farmtractor9900
    Farmtractor9900 Light Load Member
    162
    433
    Nov 6, 2020
    Depends on the cables already installed. 1/0 AWG battery cables should be used on power inverters rated up to 3500 watts.
    invertersRus.com
    86scotty and Rideandrepair Thank this.
  4. Qbf594
    Qbf594 Road Train Member
    1,642
    8,715
    Aug 15, 2019
    Southern Canadian annex, NY
    Honestly the reason the Big companies put timing circuits on those inverters is because it costs them less to pay for the timer than to pay for your dead batteries, jump start, missed delivery etc.
    The battery banks in these trucks are optimized for CCA to start the truck NOT deep cycle amp storage.
    Might want to read up on how much amps/watts you plan to use and for how long before you end up cold and embarrassed in a lot in Fargo calling your company...
    Rideandrepair and p608 Thank this.
  5. Glenn West
    Glenn West Light Load Member
    88
    37
    Apr 22, 2016
    Put solar on that truck
    Rideandrepair Thanks this.
  6. Qbf594
    1,642
    8,715
    Aug 15, 2019
    Even solar needs storage batteries.
    I use a little generator from harbor freight unless it's a 15 minute quick cooking job off my batteries.
    I keep the engine running if I'm using the inverter. And I have a personal mpg goal for this truck. Idling kills me. I was at 7.1 until winter cold. Now 6.7
    Rideandrepair and RocketyMan Thank this.
  7. Hollywoodsaint
    Hollywoodsaint Light Load Member
    237
    222
    Jun 20, 2020
    Hollywood California
    I always idle the truck when you use an inverter....Hooray for 6000 watt sine inverters =)
    Rideandrepair and 86scotty Thank this.
  8. Qbf594
    1,642
    8,715
    Aug 15, 2019
    Holy moly you hosting a rave in the trailer? How do you use 6000w?
    Bumper, Rideandrepair and 86scotty Thank this.
  9. 86scotty
    86scotty Road Train Member
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    Solar has nothing to do with this, nor would it help.
  10. 86scotty
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    If you don't understand that unhooking any post of any battery is itself a kill switch then you don't need to fool with this. Have someone do it for you.
  11. Hollywoodsaint
    237
    222
    Jun 20, 2020
    LMAO....no, I just saw a good deal on Amazon and went for it.
    Figured better to have enough and not need it than not enough and need it....
    Bumper, D.Tibbitt and Rideandrepair Thank this.
