I have a eaton fuller transmission and a small block Cat motor c13 i believe... for the past 2 wks my truck bogs down in 10th gear as it hits 1500rpm just as the turbo should cut on. Turbos and motor work great in all other gears. But in 10th , no dice. It goes into gear fine....
And when i say "bog" my exhaust sounds very loud and makes a sound almost like a jake brake... please help
Power loss in 10th gear
Discussion in 'Questions From New Drivers' started by RudyBHauling, Sep 20, 2018.
Are your fuel filters dirty?
Lepton1 Thanks this. -
Bring it to a dealer and have them run through it. It maybe a cac.
Head gasket can make that sound.
Sounds like fuel pressure falling off.
Change your filters first -
Very interesting scenario here when did you last get the air filter changed or cleaned out? Its a process of elimination from here try the fuel filters dirty fuel although you'd have issues in any gear not just 10th if your engines short on fuel same with the turbo your giving it the revs in all gears so it'd be causing trouble in every gear as well best off taking it in to a qualified auto technician.
Thank you brother! Thats exactly what it was... thanks again, i was nervousKB3MMX and WesternPlains Thank this.
Thanks brother it was the fuel filter... im new to the trucking biz... haven't changed the filter since last summer smh... now i know to change every 3-6 months.. thanks man cheersKB3MMX Thanks this.
You guessed it! Dirty filter it was... thanks manKB3MMX Thanks this.
It was filthy! I switched it out now she runs good as new! Thanks brotherKB3MMX and WesternPlains Thank this.
