Can this gasket easly be replaced or whole gear box has to be disassembled?!
This is how bad it is just after 500 miles !
Power steering gear box leak
Discussion in 'Ask An Owner Operator' started by pavrom, Sep 8, 2023.
Page 1 of 3
Are you gonna try to fix yourself, or hire it out?
I believe there is a repair kit for $35. Valley truck parts sells it
Siinman Thanks this. -
Myself
Try and snug down the bolts, might slow the leak a bit if they're just a bit loose. Looks like you'll need an external torx head socket.
Keepforgettingmypassword and Siinman Thank this. -
Put a reman on it and be done.
The gear box is nothing to be messing with if you are not familiar with the internals.skallagrime, boneebone, Keepforgettingmypassword and 5 others Thank this. -
looks like it was messed with before, it isn't hard to replace, just take your time and follow the instructions carefully.
Keepforgettingmypassword, JoeyJunk, Opendeckin and 3 others Thank this.
Earlier this year steering boxes were in short supply ..
May want to get parts before tear down.
Might as well do the hoses while your at it.Keepforgettingmypassword Thanks this. -
I was thinking the same thing when I read this. Ha haLong FLD Thanks this.
Page 1 of 3
