Power Steering issues
Discussion in 'Experienced Truckers' Advice' started by Etex Driver, May 8, 2021.
  1. Etex Driver
    Etex Driver Bobtail Member
    May 8, 2021
    Have a 2013 cascadia having problems as my day progresses with turning. Early in the day it's fine but as day goes on it gets harder to turn if I let off accelerator.Any ideas as to what could be the cause?
    Shawn2130 Thanks this.
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Have you examined the fluid?
    If it's turning black. It's a sign of seals detonating. Could also be time to do a simple change. If it's old fluid.
    Maybe it's low.
  4. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,900
    Sep 20, 2015
    Southern Ontario
    Been dealing with that issue myself.
    Did the fluid flush first.
    truck used to use power steering fluid but the company boss’s son cheaped out and said that hydraulic oil is the same for less money.
    Been getting worse power steering operation since then.
    Oil was getting hot and smelling burnt.
    When I drained the oil out, it was practically like water. Pouring out quickly.
    Now I’ve flushed the system out and put in engine oil.
    The engine oil did better but not 100%.
    So we are looking at replacing either the pump or steering box.
  5. snowwy
    20,612
    13,333
    Jul 6, 2009
    Atf is the way to go.
  6. Rideandrepair
    17,575
    56,939
    Aug 8, 2015
    Need to change filter in reservoir if equipped.
    mitmaks, uncleal13 and Cattleman84 Thank this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Mine was getting whiny, steering fluid was seeping out onto top of reservoir.
    I changed the fluid, the filter and the o-rings on both caps.
    Works good now, and no leaks.
    Shawn2130 and Rideandrepair Thank this.
  8. wore out
    wore out Numbered Classic
    17,421
    216,767
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Classic symptoms of a bad pump.
  9. Ridgeline
    22,750
    123,967
    Yep, people think it isn't the pump but most times it is.
    I would not work for a cheap company like that, let alone one with a moronic owner who thinks it is the same, it isn’t.
  10. Shawn2130
    896
    1,900
    Sep 20, 2015
    Southern Ontario
    I’ll be using ATF once the pump has been changed.
  11. bad-luck
    bad-luck Road Train Member
    3,447
    6,357
    Nov 16, 2013
    Baltimore, Maryland
    Check oil level first. If the level is ok. Then you most likely need a pump or steering box. FYI always use engine oil for power steering. Reason being is, if the seal goes you do not want power steering fluid going in to your engine oil.
    Etex Driver and Shawn2130 Thank this.
