Power steering leak. Lost all fluid. Pump still making noise
Discussion in 'Experienced Truckers' Advice' started by JC1971, Dec 20, 2024.
  1. JC1971
    JC1971 Road Train Member
    2,688
    9,832
    Jul 29, 2013
    Southwestern U.S.
    A loose fitting allowed all the power steering fluid to leak out. Roadside service fixed leak but after 30 mile drive to terminal, power steering still making some noise. Road tech had said that the loss of fluid might have damaged pump and might need to be replaced or it's air in the system.
    Does pump need to be replaced after complete fluid loss? The main thing is I don't want to lose power steering out in the middle of nowhere.
  3. Arctic_fox
    4,763
    27,255
    Sep 16, 2016
    50/50 it either did damage and will go out when it decides to go out. Or it didnt. If it was me id just run it if its working fine and giving no other symptoms.
    That said an easy way to rule out air is to pop the cap and shine a light in there and look for froth or bubbles. If you got froth or bubbles, then its air. If you want to fix it. Just drain the system, make sure everything is tight and then flush the system and fill.
  4. Long FLD
    Long FLD Road Train Member
    13,290
    56,008
    Mar 4, 2015
    The one time I lost all the fluid I was in the middle of nowhere Idaho and didn’t have phone service. I patched it up and when I got to Lewiston I needed a pump. I can’t say if it was from losing all the fluid or if it was from me using the only extra oil I had to top it off, which was Rotella 15-40. Lol
  5. 062
    062 Road Train Member
    6,402
    34,235
    Oct 20, 2013
    It most likely overheated and done some damage, but hard to say how much.
    I’d change the filter and ride around town 20-30 minutes see how it does.
    Rideandrepair and JC1971 Thank this.
  6. 201
    201 Road Train Member
    12,978
    26,759
    Apr 16, 2014
    high plains colorado
    Try a little STP,,:eek:, hey, the pump is probably fried anyway, and not the end of the world, but depending on how long it ran dry, best to replace the pump. If it's growling, a bushing or bearing is toast and will take out the main seal complicating matters considerable.
    Rideandrepair, JC1971 and 88 Alpha Thank this.
  7. dosgatos
    dosgatos Medium Load Member
    628
    1,338
    Sep 18, 2012
    what kind of noise? IF it's air, turn the steering wheel all the way hard to the left, then to the right and repeat a few times to move the air out of the steering box. Air in the system sounds like rice krispies. Google air entrainment and cavitation.
    Rideandrepair, 201 and JC1971 Thank this.
  8. xsetra
    xsetra Road Train Member
    5,205
    7,161
    Aug 21, 2011
    I had the power steering lose fluid while driving, isn't that big of an issue. Just need to use the armstrong setting.
    Highway speeds was really no different than normal. You really have to tug on the wheel when driving slow or moving while trying to park.
    I changed my pump when I got back home. The next day a couple hundred miles later.
    I'm sure your pump has some damage internal. How bad, not sure. But I am sure there's some damage. Best solution is to change it.
    Also if you don't know how to set the stops and poppets. Hire someone to replace it. I installed my first pump and broke it. Thankfully the parts house replaced using warranty. I hired them to put the second pump in. I have been told it is easy to install. I figured it was even easier and cheaper for me to hire it out.
    Good luck.
    Rideandrepair, Numb and JC1971 Thank this.
  9. JC1971
    2,688
    9,832
    Jul 29, 2013
    Southwestern U.S.
    There's no way it can be safely driven without power steering. The older trucks without it must have had a lower gear ratio for the steering. It was impossible to make a turn in one try.
    Rideandrepair Thanks this.
  10. Inderjit
    Inderjit Heavy Load Member
    785
    743
    Sep 17, 2017
    Some steering systems can be hard to get the air out of. One of the best was is to put a jack under the steering axle and lift the weight off the tires then crank the steering from lock to lock 3 or 4 times with the engine shut off.
    If that does not help then the pump has been damaged and needs to be changed as metal from the pump will harm the steering gear and you will be replacing that as well.
    Rideandrepair and dosgatos Thank this.
  11. 201
    12,978
    26,759
    Apr 16, 2014
    That's true. UHaul/moving story. Several( many?) years ago, we rented a UHaul box truck, biggest one they had. Spent all morning loading the dang thing, time to leave, start the truck, oil pouring out the bottom. P/S pump fried. UHaul said they could have someone by in 3 hours, well we had people waiting for us on the other end, I told my gf, let's just run it. It was mostly hwy. and turning was difficult, but we made it. UHaul had the truck towed back.
