Power steering problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by homesick, Jun 6, 2015.
  1. homesick
    homesick Light Load Member
    161
    8
    Nov 26, 2007
    memphis,tn
    I have a 99 century with a detroit 12.7 replaced the steering box and now the power steering doesn't work. When you start to turn the wheel in one direction it keeps turning until it locks. I replaced the steering box with 3 new ones and a power steering pump anyone else had that problem
  3. AnneK
    AnneK Bobtail Member
    41
    6
    Apr 30, 2014
    Did this start when you replaced the gearbox or is this why you replaced the gearbox? Have you checked the lines to see if there are any restrictions? Sometimes they can have a collapsed inner liner and the outside of the hose seems fine. I had one where fluid kept pumping out of the reservoir and all the hoses looked great, but when I took them down one was almost completely collapsed inside. Not the exact same issue, but it sounds like your pressure isn't being released. If it started when you replaced the box, are you sure you got all the lines back in the right positions?
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    This is usually a bent torsion bar inside the gears rotary control valve. Are you replacing the gear with reman units are simply having your original one rebuilt?
  5. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    You keep turning until it locks?
    What is locking?
  6. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    1 remain from truck pro and 2 from freightliner once you start to turn it it turns by itself until it can't anymore
  7. AnneK
    41
    6
    Apr 30, 2014
    What he's talking about is the end of the throw where the steering wheel stops turning on either side, like when they say to bleed your power steering system turn the wheel lock to lock. That kind of lock.
    Thinking more about it as well - do you have a tie rod going from left to right or a cylinder on the right side or another box on the right side? If it's the type with lines to a cylinder or box on the other side, it could be that the pressure isn't shutting of to them. What happens if you don't let go of the wheel and try to stop it or even reverse and go the other direction? Are you about to easily turn it back, force it back or there's just nothing you can do until it hits the lock and stops itself and then it somehow frees up? Any other symptoms like noise or chatter? Aside from the box and the pump, anything you've inspected and ruled out completely?
    Also it's really important if this is the reason you changed the box the first time or something that happened after you changed the box. I mean, obviously the problem isn't the box - no way you got 3 boxes with the same strange issue - but the answer to this question determines whether or not you have to review your work or your original diagnosis.
  8. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    What else could cause the problem
  9. Heavyd
    7,829
    6,280
    Feb 4, 2009
    This can happen with really messed up caster, like severe negative caster, but this also comes with really hard to control handling characteristics. Have you had any other suspension or front end work done recently? Why was the original steering gear changed? If you jack up the front end so the steer tires are off the ground, with the engine running, if you move the steering wheel and then let go, does it continue to turn on its own until it hits the stops, or is this just when you are driving it?
  10. EHB
    491
    209
    Apr 26, 2011
    Newfoundland
    Well let's see.
    Power steering is simply a hydraulic pump, pumping a hydraulic fluid threw lines to move a shaft.
    It is a stead flow and has a releaf values to dump the pressure back to tank and then back to the pump.
    If any of the pressure releaf values are not working correctly or cloged, you will then have a one way hydraulic ram moving only one way direction and not able to release the pressure off the line to go back the other way.
    HopeOverMope Thanks this.
  11. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    I haven't had any front end work done the shaft were stripped on the steering box other than that no power steering problem
