Power steering problem.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Slowpoke, Jun 28, 2009.
  1. floydP
    floydP Bobtail Member
    Was just reading over this post from 2009. I'm having the similiar issues with my 03 Peterbilt turn left with deadpots. I did notice that you had asked the gentleman if he had lowered his truck. so since I had lowered mine i was wondering if you had any other ideas for a fix. the dead spots only turning left. Anything would be helpful,
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    You could have some blockage in the lines.
    When's the last time you flushed your power steering system or changed the power steering filter (if equipped)?
    Check your steering shaft coupler for binding.
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Lots of good information in this post. Read it over. If you have any further questions, feel free to ask.
  5. truckershawn33
    truckershawn33 Bobtail Member
    6
    Can any one tell me why my power steering reservoir all of a sudden is overflowing. No work was done to it. It just started this week but turns fine. Just last week levels were perfect no its over flowing
  6. truckershawn33
    6
    Truck is 2012 t660
  7. AModelCat
    165,312
    Does the fluid look foamy? If it does you most likely have a leaking hose/fitting on the pump inlet, drawing in air and expanding the oil with air bubbles.
  8. boneebone
    2,297
    2,372
    Mar 13, 2009
    Does your power steering reservoir have a filter?
    If it does and has never been changed, it could be clogged causing a restriction.
  9. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
    Engine oil pushing through a failed seal on the power steering pump. Is the fluid black?
    If it is a tandem steer truck it could be a leaking power steering cooler putting coolant into the oil but highly unlikely.
    TheBaron97 and SAR Thank this.
  10. Heavyd
    7,829
    6,280
    Feb 4, 2009
    Yep, either engine oil being pushed or sucked past the seal, or air is getting drawn in and causing it to foam. If no foam, then it is sucking in oil from the engine side of the drive.
    SAR Thanks this.
  11. truckershawn33
    6
    Yes i have a filter changed it today and it was black just like engine oil. Darn
