Power steering problem.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Slowpoke, Jun 28, 2009.
  1. truckershawn33
    truckershawn33 Bobtail Member
    6
    So how do i stop this seal issue thanks guys
  3. AModelCat
    161,595
    I haven't actually seen that issue before personally (engine oil going into the power steering system). I would say its likely you'll need to replace the power steering pump. I'd take my suggestion with a grain of salt though. Someone will chime in shortly I bet to confirm or deny it.
    SAR Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    I worked in a shop with a lot of 4070B's. They had around 800.000 miles on them and did that fairly regular ( motor oil in P/S that is ) overflowing from the reservoir. They had us put new seals in pumps with badly worn shafts. Never had a problem with one. Possibly the new seal lip was in a different spot?
    Personally I would just replace the pump. It is only steering.
    SAR, Heavyd and pushbroom Thank this.
  5. Heavyd
    Heavyd Road Train Member
    7,811
    6,264
    Feb 4, 2009
    Right, like BoxCarKidd said, it is likely the shaft seal of the pump itself. You can replace it, but usually the shaft has worn a groove where the seal lip was riding and because of that may leak again. So it is just best to replace the pump since you have to remove it anyway.
    SAR Thanks this.
  6. truckershawn33
    6
    Anyone know how many hours kw shop should take to replace powersteeeing/fuel tandem pump!!
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Kind of a pain... Your talking about a MX I assume.
  8. truckershawn33
    6
  9. Arodjasso23
    Arodjasso23 Bobtail Member
    13
    Apr 18, 2019
    I have a 2006 kenworth t800 this morning I was going to work and noticed that it is super hard to steer to the right steering to the left is good but steering to the right seems impossible
  10. Heavyd
    7,811
    6,264
    Feb 4, 2009
    Either the poppet relief for that direction is stuck open or the gear is internally leaking past the piston seals in that direction, or the rotary control valve has failed for that direction. All in the gear. Replace the gear with a reman unit.
    Arodjasso23 Thanks this.
  11. Arodjasso23
    13
    Apr 18, 2019
    Just replaces the pump and nothing. Made sure everything is well greased but the problem continued. I will look into replacing the gear tomorrow, but out of curiosity I notice that when I turn the wheel there’s a cracking noise near the driver wheel could the kingpin cause the steering issue?
