Power steering problem.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Slowpoke, Jun 28, 2009.
  1. Heavyd
    Heavyd Road Train Member
    7,830
    6,281
    Feb 4, 2009
    I have never seen a binding kingpin cause stiffness in only direction, but it could be possible. Best way to check is to jack it up and turn the wheels side to side by hand to see if one way is too tight.
  3. Arodjasso23
    Arodjasso23 Bobtail Member
    13
    Apr 18, 2019
    When I hack it up I can move the wheels no problem it only gets stiff when the wheels are on the ground. I replaced the gear today and still nothing
  4. Heavyd
    7,830
    6,281
    Feb 4, 2009
    That doesn't sound right to me. Stiff only in one direction, you replaced the gear and pump, turns fine by hand with jacked up, and you still have the same problem? Disconnect the input shaft to the gear and see how your steering wheel turns by itself.
  5. johnjohn1984
    johnjohn1984 Bobtail Member
    7
    Jan 28, 2020
    hello, i also have a 2001 pete 379, i have put a new power steering pump and new gear box and hand all the king pins replaced and also realigned, but have a hard steering wheel with alot of kick back and road wonder. did you find you're problem with your truck? thanks
  6. CarHauler757
    CarHauler757 Bobtail Member
    5
    5
    Oct 7, 2019
    Same issue. But with a Sheppard box in a cascadia. New box. Pump pressures checked good. Had front end checked and aligned twice. Still turns easy as pie to the right. Turning left acts as if air is in the system. Rev it a little and the stuff I goes away
  7. Aria
    Aria Bobtail Member
    Hi ,, would u please tell me what u done to fix it i have hard left turn ,, also i lowered the truck last year ?
  8. Mtw
    Mtw Bobtail Member
    I have an 2012 Cascadia and when I crank up in the morning my steering is fine but once everything heats up it starts getting harder to turn mostly but will be loose at times
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,562
    6,648
    Aug 26, 2014
    I did not read the 4 pages before your post. Probably should have started your own.
    Sounds like a pump to me but you can do tests or just start changing parts.
    Heavyd and Mtw Thank this.
  10. Mtw
    Mtw Bobtail Member
    Thx...I have pump going to change it and go from there
  11. bluerhino
    bluerhino Light Load Member
    107
    7
    Mar 10, 2013
    Hi hope you are doing. I have the same issue new kingpins, carrier bearing have same issue how did you resolve the problem. Thank you
