Power steering pump question
Discussion in 'Freightliner Forum' started by tntruckdriver, Nov 4, 2012.
  1. steven76
    steven76 Light Load Member
    58
    17
    Oct 9, 2014
    Electrical issue ? I talking about the hose. Not wire. It's no wire at that area. Thank you for your help
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    will hose get hot and smoke when excessive pressure is applied inside ? I think no...
  4. Animosus
    Animosus Heavy Load Member
    734
    2,916
    Dec 7, 2015
    SE Wyoming
    I have seen it many times, the starter will ground out through the power steering hose if the battery cable is loose/corroded. It makes you scratch your head the first few times.
  5. steven76
    58
    17
    Oct 9, 2014
    All of you was right. Mr Genius "angel" service guy at miami forget to connect ground to my engine after he took it off. So all ground went to hose what's somehow connected to the ground. Gear box high pressure air hose ... and more. So I had to change 3 times oil pump high pressure hose and break high pressure hose also my air dryer inside spring and fittings burned plus oil pump for gear box went out because oil went away. So it's about $4200! Because one wire! Learn pls and put additional ground cable from your battery to your transmission or engine.
