Powering CB in 2019 Cascadia
Discussion in 'CB Radio Forum' started by Moondawg1964, Nov 17, 2018.
  1. Moondawg1964
    Moondawg1964 Bobtail Member
    27
    Nov 17, 2018
    Alabama
    So I got into a new Cascadia the other day. It's a 2019 that came with a dash mount for the CB. When I plugged and wired the coax up, got a lot of static coming through. Did some YouTube research (as well as here) and the best solution I can come up is wiring the CB directly to the battery.
    Kind of a newbie at this so any suggestions, help etc on the best way to do this will be welcomed.
  3. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
    Connect to power leads at the main fuse box behind the passenger dash.
    Moondawg1964 Thanks this.
  4. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Newbie at hooking up a CB, or Newbie at using one?
    CB's have some static sound when you turn them on...not like a cell phone...
    slim6596 Thanks this.
  5. Powder Joints
    7,996
    8,427
    Sep 25, 2007
    Rosamond, SoCal
    The most important thing, no more than 6 inches from the power source before you fuse it, to be safe fuse pos and neg. The battery is always the best source, not the easiest. Open the glove box, pull out the liner and there is a fuse block with direct battery hook ups, If you dont know what your doing check with your company mechanic first.
  6. rabbiporkchop
    9,678
    6,546
    Feb 9, 2012
    Wapwallopen, Pa
  7. LoSt_AgAiN
    LoSt_AgAiN Heavy Load Member
    766
    3,855
    Sep 7, 2018
  8. Slowmover1
    1,491
    1,210
    Oct 25, 2015
    Fort Worth
  9. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Yeap..Right now thats about all there is out there for mounts for the cascadia..
    I have an idea in mind,just makeing the time to get a shop to do it..
    If it helps i uploaded a few vids on power/gnd/coax and antenna results useing an analyzer on youtube..
    1 vid is loading now and a cpl more done..
    Im no tech or pro just a lil self testing trying to learn as i go..
    Feel free to comment good or bad..Same name i use here craig_sez
  10. Scoot 1971
    Scoot 1971 Light Load Member
    265
    348
    Nov 22, 2018
    I mounted antenna on back of cab, the upper s/s bar where the cable hose springy things slide left to right. Ran my own coax under cab and thru firewall up to radio. This set up got me nothing! Took it to cb shop, they ran their coax thru cab and hooked it up to my cb. They did change my crap antenna and I have had really good radio performance since. They did a really nice job as I can't see the coax at all except for the ends of course. This cost me about $125 and a little over an hour.
    My truck is a 17' Cascadia.
  11. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Yeah on the 16 i had it was across the top of the sun visor(my stryker was a lil to big to keep in the cubby hole)behind the astics of the pillar down to floor and out the firewall..Then up behind the plastics where signal light is to top of upper door hinge and out to mirror arm ant mount..Not alot different to the 19 i have now..
    On my 19 i still didnt like my radio up top so now its dash mounted with a slightly coax routeing..
