Powersteering and eng noise
Discussion in 'Volvo Forum' started by sammaxlee, Apr 4, 2021.
  1. sammaxlee
    sammaxlee Bobtail Member
    33
    Jun 20, 2019
    My truck is 2014volvo D13 ENG .When I turn the handle to the left or right I heard noise from the inside eng, not the power steering system .Anyone who knows this isse.please advise me thank you
  3. Jenn72
    Jenn72 Medium Load Member
    604
    1,454
    Jun 7, 2019
    Could it be your gearbox? I had one go out on a 2015 freightliner and the noise sounded just like you described.
    When the shop investigated it, it came back as my gearbox not the power steering.
  4. sammaxlee
    33
    Jun 20, 2019
    Thanks.what do you mean a gearbox?X-mission? I got noise from inside ENG
  5. Jenn72
    604
    1,454
    Jun 7, 2019
    When mine was going bad it sounded like it was coming from the engine.
    A bad or failing gearbox is typically caused by lack of proper lubrication and service. ... If you notice this grinding sound when you steer left or right, contact a mechanic so they can quickly diagnose and replace the steering gearbox if needed.
  6. AModelCat
    164,822
    Power steering pump is bolted to the engine and is driven by the gear train. Other than that the steering system has zero interaction with the engine.
  7. bad-luck
    bad-luck Road Train Member
    3,439
    6,332
    Nov 16, 2013
    Baltimore, Maryland
    Check the power steering fluid level and make sure it is full. Could be the power steering pump (it is gear driven) could be the steering box it self. Best to have two people to diagnose it.
    sammaxlee Thanks this.
  8. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Make sure someone removes that steering pump and check the idler gear in the geartrain, its a sickness with the year yoiu have.
    Socal Xpress Thanks this.
  9. RoadRanger^^
    RoadRanger^^ Medium Load Member
    317
    118
    Apr 17, 2018
    Columbus, OH
    I think most of the volvo’s have that issue. My Volvo make that sounds for years and its still running no issue but just maling whining sound
  10. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Have you changed the power steering filter and flushed the fluid. Believe Volvo wants that done every 100k.
    Cheap 2 quarts of Dexron 3 and a $10.00 filter. Try that but may have waited to long and the fluid has turned into a cutting fluid and destroyed the pump
  11. RoadRanger^^
    317
    118
    Apr 17, 2018
    Columbus, OH
    Yes i did. Might be something with steering pump but i will wait till it gives up. i hate throwing money just like that on parts :(
