Pre emission vs Emission engines
Discussion in 'Ask An Owner Operator' started by KullenTrucking, Apr 4, 2021.
  1. KullenTrucking
    KullenTrucking Light Load Member
    62
    31
    Apr 26, 2019
    South Florida
    Hi
    If you were a new owner operator starting out in today’s times, would it be a pre emission or an emission engine?
    thanks
  3. Cat sdp
    Cat sdp . .
    21,308
    76,228
    Apr 8, 2012
    Orion's Belt
    Brand new or pre-dpf....... nothing in between but that’s me.....
    There’s plenty of guys on here that do a 30K cascadia........ god bless them
  4. Long FLD
    Long FLD Road Train Member
    12,886
    53,983
    Mar 4, 2015
    What’s your budget? How mechanically inclined are you? Do you have the ability to work on an 18 year old truck so the labor costs of a ton of small repairs don’t kill you?
  5. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    Per Emissions no doubts here
    kuzima93, baha and KullenTrucking Thank this.
  6. KullenTrucking
    62
    31
    Apr 26, 2019
    South Florida
    Budget under 60K. Very basic knowledge of repairs/maintenance, so I’d have a good mechanic that I could rely on. With that said, I’m willing to learn as much as possible. As many things that 1 man could preform on his own.
    Bean Jr. Thanks this.
  7. KullenTrucking
    62
    31
    Apr 26, 2019
    South Florida
    Majority of rigs I’m looking at have DD15’s. Some are Cummins
    BackwoodsGA Thanks this.
  8. Long FLD
    12,886
    53,983
    Mar 4, 2015
    You need to at least go 07 and older if you can’t find a solid 03 and older, in my opinion. Anything 08 to about 2016 or so should be avoided. In your budget a DD15 would be right about the point of needing a bunch of work.
    Bean Jr. and ChevyCam Thank this.
  9. Arctic_fox
    4,510
    25,497
    Sep 16, 2016
    It depends. I went with a low mile 2017 emissions truck and its working so far.But im also moderately mechanically inclined and got a warranty on the emissions systems and engine and have enough computer knowledge to brute force my way through the stupid with a laptop. Honestly there are pros and cons to both.
    For example an emissions truck is unlikely to face bans, you can get them new so warranties are a thing. They tend to get better overall mileage, parts are going to be easier to find in general depending on what motor you get. And you are less likely to get nailed as often by the DOT and are usually a bit lighter. How much varies by truck and engine combo though.
    The downsides is they need to adhere to a STRICT maintance schedule, they are really finnicy on maintaince, you NEED a several thousand davie4 or simular tool to clear minor problems or you will face thousands in towbills and repairs, they have bendex #### built in almost as an afterthought. Def is annoying, computer parts are expensive and they are easy to gernade the electrical systems on. And used ones are a gamble on how much work needs doing to be viable. And they are expensive to buy.
    Pre emssions have the advantage of being able to be fixed ANYWHERE, are easy to spin your own wrench on, dont have all the computer ######## to rely on, are typically easy to get used parts for, are more linient on maintance schedules, and can be limped with minor problems. And can be had for cheap.
    The cons are the current managment is trying to ban "evil polluteing things" via cali style bans and/or introduce carbon credits which may make them non viable soon. They tend to be pretty worn out so finding a good one can be a huge challenge and even good ones are going to have worn out things on them that are likely to break. Some places wont let you haul their loads with an older truck. You almost literally cant warranty them. And DOT may be more likely to harass your old truck then a new one.
    Upto you what set of pros and cons are worth more to you though.
    kuzima93, mjd4277, ChevyCam and 5 others Thank this.
  10. KullenTrucking
    62
    31
    Apr 26, 2019
    South Florida
    What work would that be?
  11. Long FLD
    12,886
    53,983
    Mar 4, 2015
    On a DD15 in that price range? Probably a one box system replacement on the emission system. You’re really banking on the previous owner keeping up on emission maintenance and if they haven’t then it’s going to come out of your pocket.
    KullenTrucking Thanks this.
  12. jinxutoo
    jinxutoo Light Load Member
    134
    224
    Jan 17, 2012
    Illinois
    I've been on both sides of your question. I had a truck I put 1.7 million on, 03 International 9400, good ole truck. The last year I had the truck it about broke me,between parts, repairs, down time and the stress.
    I bought a 2014 Prostar with a cummins, payed cash, had 420,000 on it. Charge air cooler went bad, had to put new clutch in it around 500,000 and it had the bendix wingman, (terrible system)after treatment issues constantly. So I payed around $44,000 for the truck put another $15,000 into it worked it to 590,000, cams went bad. Traded it off for a brand new truck and I will never buy used again. I've got 210,000 on this one now and getting rid of it in October for a truck I ordered, probably have around 340,000 when I get rid of it.
    If you buy used, I would look for an O/O getting rid of his and get maintenance records. When this one goes it will still have 2 years and 160,000 miles left on the manufacturers warranty.
    kuzima93, John E., Bean Jr. and 2 others Thank this.
