Hi all, OK I'm racking my brain trying to find the "right" way to start a pre-trip inspection. i have looked on other sites and from what I'm seeing no one does it the same way. From my understanding it has to be the same way. Than again I'm not sure. Even in the DMV manual it really isn't to clear about when to do what. I have been looking and looking most sites give me the steps but none are clear on really what order to go in. If anyone can give me or know somewhere that i can find a thorough pre-trip inspection i would most definitively appreciate it thanks all drive safe.
Pre Trip Inspection ahhhhh help!!!
Discussion in 'Questions From New Drivers' started by lionheart0901, Aug 19, 2010.
There is nothing saying you have to do your pre-trip in a particular order. You just need to cover it completely. Break it down for yourself. Check the motor and motor components (alternator, starter, etc...) check all your hoses, check all your fluids, check all of your suspension components, Brake components, stuctural and components (frame, fifth wheel, king pin, cat walk, welds, mounts, bushings etc...) Tires and wheels, axels etc... Drive components, u-joints, drive shafts, airbags, level arms. Go over your entire air system doing you pressure test and checking lines and glads. Then do your lights, all of them including under the trailer on your rig, and turn signals. Check mirrors, windshields,horns make sure there are now body components falling off or in bad shape, mud flaps etc... I sounds like a lot but a little practice and its like brushing your teeth. Just check everything and you aren't going to fail. Good luck!
lionheart0901 Thanks this. -
pretrips are easy it just takes time to check and learn the pazrts and what to you are looking for c1 has a good pretrip set up and like chomi said do it any wat you want to but make sure you cover all your pti parts so because each state has different standards that they require for the pti
lionheart0901 and WVroadtrucker1965 Thank this. -
I'll try to break this down in the order I learned it and hopefully it will make sense to you. don't be discouraged, when I first heard the pre-trip and was told I'd have to know all this in my head I freaked out, but after going thought the pre-trip over and over in my head it's not that bad. It will come naturally to you after a while. Don't stress buddy, you'll get it down!
The Pre-Trip Inspection:
I'm going to check my 4 L's, LIGHTS, LICENSE PLATE, LEAKS & LEANS.
Lights - Properly Mounted and Secured (PMS) not cracked or broken.
License Plate - PMS and up to date
No Visible Leaks or Leans.
*open hood*
Windshield Rubber Seal - PMS not cracked or broken.
Windshield Wiper - PMS, with proper tension and no metal touching the glass.
Moving onto the engine bay, now this varies with the tractor you are using, some things are on the other side of the engine bay on other tractors.
Coolant Res. - PMS not cracked broken OR LEAKING and Filled to the proper level (apply "Not Leaking" to anything that could leak fluids, oils, or air).
Top and Side of the engine - Not Leaking
All hoses - not cracked broken or leaking
Gear or Belt Driven Alternator - PMS not cracked or broken.
Fan Belt - no more than 3/4" of play, not frayed or broken.
Hoses and Clamps - PMS not cracked broken or leaking.
Frame - No Welds or missing bolts
*Moving to the Drivers side of the Engine bay*
All hoses - PMS not Cracked Broken or leaking
Oil - Filled to the proper level, not milky or cloudy
Belt or Gear Driven Air Compressor - PMS not Cracked Broken or Leaking
Belt or Gear Driven Power Steering Pump - PMS not Cracked Broken or Leaking
Steering Shaft - PMS not Cracked Broken or Bent.
Steering Gearbox - PMS not Cracked Broken or Leaking
Power Steering Res. - PMS not Cracked, Broken or Leaking and Filled to the proper level.
Spring Hanger - PMS not Cracked or Broken, no missing bolts.
Leaf Springs - PMS no more than 25% cracked broken or scissored.
U bolts - PMS not Cracked or Broken
Shock Absorber - PMS not Cracked, Broken or Leaking
Pitman Arm - PMS not Cracked or Broken
Drag-Link - PMS not Cracked or Broken
Castle Nuts - not missing and Cotter Pin is in place
Steering Knuckle - PMS not Cracked or Broken
Air Lines - PMS not Cracked, Broken or Leaking
Air Canister - PMS not Cracked, Broken or leaking
Slack Adjuster & Pushrod - PMS not Cracked or Broken, no more than 1" of play with the brakes released
Inner Seal - not leaking
Brake Pads - no less than a 1/4" of pad left
Brake Drum - PMS not Cracked or Broken
Inner Wheel - PMS not Cracked or Broken, NO WELDS.
TIRES: you work your way from the inner sidewall to the outer sidewall.
Inner Sidewall - Remember A.B.C. (Abrasions, Bulges, Cuts) so you would say "Inner Sidewall, no Abrasions, Bulges or Cuts" the first time, then just ABC's anytime after that as long as your tester is aware of what ABC's means.
Top of Tire- Here you would remember IDC (Inflation checked with a tire gauge, Depth no less than 4/32" on the steer tires, and Condition,) Condition you're looking for things like Divots, Missing Chunks, or Separation and even tread wear across the top of the tire. during the test all you would need to say is "Checking the top of the tire for proper inflation, making sure there's no less than 4/32" of tread on the steer tires, and I'm looking for even tread wear and no missing chunks"
so to sum it up you would continue like this:
Inner Sidewall - ABC
Top of Tire - IDC
Outer Sidewall - ABC
Outer Wheel (Aluminum) - PMS not cracked or broken, NO WELDS, no missing lug nuts, no shiny spots or shavings indicating a loose lug.
Outer Wheel (Steel) - PMS not Cracked or Broken, NO WELDS, no missing lug nuts, No rust streaks indicating a loose lug.
Outer Hub Seal - Filled to the proper level, not leaking
*close the hood*
Steps - PMS not cracked or broken and free of debris
Fuel Cap - PMS Inner seal not Cracked Broken or missing
Fuel tank - PMS not Cracked Broken or leaking
Fuel Tank Straps - PMS not Cracked or Broken
Door Mirrors - PMS not Cracked or Broken
Door Handle - working properly
Door Hinges - working properly
Door Seal - PMS not Cracked, Broken or Missing
BC Rated Fire Extinguisher - PMS not Cracked, Broken or leaking, and filled to the proper level in the green.
Storage Box - you should have three (3) Emergency Triangles, Spare Fuses and/or Circuit Breakers.
*Enter Cab*
Windshield - PMS no cracks longer than an inch (1") or chips larger than a quarter.
*Turn key on, do not start truck*
Check that all your gauges rise and fall within 5 seconds to show they are working, make sure your ABS light is functioning.
*Safe Start the truck*
SAFE START: Parking brakes set, truck is out of gear and clutch pedal is to the floor, start vehicle and slowly let the clutch out.
Oil Pressure - rising to the proper level
Volt Meter - Rising to the proper level (between 12 & 15)
check your Left signal, Right Signal, Hazards, and High beams.
City/Electric Horn - Honk, working properly
Air horn - Honk, working properly
Wipers and Washer - Working Properly
Heater and Defroster - Working Properly
*TUG TEST*
To test the Tractor Brakes, release the trailer brakes and leave the tractor brakes engaged.
To test the Trailer Brakes, release the tractor brakes and leave the trailer brakes engaged.
Test the Trailer Brakes - Tug twice with the tractor brakes OFF and the trailer brakes ON.
Test the Tractor Brakes - Tug twice with the tractor brakes ON and the trailer brakes OFF
*Service Brake Test*
Roll foreword with all brakes released at approximately 5mph, then apply hard steady pressure with your hands hovering the wheel (not gripping) to see if the vehicle pulls to one side or not.
*Shut the truck down but leave key in ON position and take truck out of gear*
*Air Brake Leak down Test*
Push the service brakes (brake pedal) and hold at 90psi for 1 min, you should lose no more than 3psi in a Class A combination vehicle and no more than 4psi in a Class B Straight Truck in 1 min.
*Emergency Brake Test*
Feather the brake pedal until the LOWAIR WARNING light and buzzer comes on AT or above 60psi
*Turn key to OFF position*
continue feathering the brakes until both tractor and trailer emergency breaks automatically apply at or below 40psi
*pop* *pop*
ok your emergency brakes have been applied
*SAFE START*
Air Pressure Gauge - Rising to normal range
Air Compressor Governor - should automatically kick off between 120 and 125psi
While you are waiting for the air pressure to build to 120psi - Ask your tester to go to the front of the vehicle and check your - High Beams, Low Beams, Left, Right, Hazard and marker lights, then ask if they would go to the rear of the vehicle and check you Brake, Tail, Left, Right, Hazard and Marker Lights on both the Tractor AND trailer.
when this is completed and your air pressure has risen to normal range, exit the vehicle.
Moving toward the rear of the tractor now:
Marker Light on side of the tractor (if there is one) - PMS not Cracked or Broken
Steps and Catwalk - PMS not Cracked or Broken and free of debris
Exhaust - PMS not Cracked or Broken, no soot indicating leaks
Loading lights & Cab reflectors - PMS not Cracked or Broken
Drive Shaft - PMS not Cracked or Broken or bent
Air and Electrical lines - PMS to the Tractor AND trailer, not Cracked, Broken or Leaking, and at a safe distance away from the catwalk.
Glad hands - Rubber Seal not Cracked, Broken or Missing
Header Board (front of trailer) - No holes or damage
Splash Guard - PMS not Cracked, Broken or Missing
Corner Marker Lights on Top & Bottom of trailer - PMS not Cracked or Broken
Frame - NO WELDS or missing bolts
Leaf Springs - PMS no more than 25% Cracked, Broken or Scissored
U Bolts - PMS not Cracked or Broken
Air Bags - PMS not Cracked, Broken or Leaking
Air Canister - PMS not Cracked, Broken or Leaking
Inner Seal - Not Leaking
Inner Sidewall of the Inner Tire - ABC
Top of the Inner Tire - IDC
Outer Sidewall of the Inner Tire - ABC
BUD SPACE - (space between dual tires where the wheels bolt together) PMS not Cracked or Broken, NO WELDS and free of debris.
Inner Sidewall of Outer Tire - ABC
Top of Outer Tire - IDC
Outer Sidewall of Outer Tire - ABC
Outer Wheel (Steel) - PMS not cracked or broken, NO WELDS, no missing lug nuts, No rust streaks indicating a loose lug.
Hub Seal - Filled to the proper level and not leaking
here you would point to the OTHER axle that you have not checked and say "I WOULD CHECK THAT AXLE THE SAME AS THIS AXLE"
Tail Lights - PMS not Cracked or Broken
Fifth-Wheel - PMS not Cracked or Broken, No space between the bottom of the trailer and the top of the fifth-wheel, no missing bolts, all the dogs are in their house. (for a sliding fifth-wheel)
Locking Jaw - Locking Jaw is around the SHANK of the Kingpin
Locking Jaw Release Bar - is in the Locked Position
Mud flaps - PMS not Cracked or Broken, no closer than 2" from the ground and no farther than 4".
K-BAR - PMS not Cracked or Broken
Landing Gear - PMS not Cracked or Broken, raised all the way up with the crank handle in its cradle.
Trailer Cross members - PMS not Cracked or Broken
DOT Tape - PMS not Cracked, Broken or Missing
Marker lights in the center of trailer - PMS not Cracked or Broken
Sides of trailer - No Holes or Damage
Door hook (Side of trailer) - PMS not Cracked, Broken or Missing
Air Lines - PMS not Cracked, Broken or leaking and at a safe distance off the ground.
Air Bags (if any) - PMS not Cracked, Broken or Leaking
BUD SPACE - PMS not Cracked or Broken, NO WELDS and free of debris.
Here, Again you would point to the OTHER axle that you have not checked and say "I WOULD CHECK THAT AXLE THE SAME AS THIS AXLE"
Trailer Door Seals - PMS Not Cracked, Broken or Missing.
Trailer Door Latches - PMS not Cracked or Broken
Rear Door Hooks - PMS not Cracked, Broken or Missing
DOT or ICC Bar (Rear Bumper) - PMS not Cracked or Broken, and has DOT Tape.
ALL lights - PMS not Cracked or Broken
License Plate - PMS not Cracked or Broken and up to date
you would then walk to the other side of the vehicle, and say "I WOULD CHECK THIS SIDE OF THE VEHICLE THE SAME AS THE OTHER SIDE." now would be a good time to just walk around the vehicle and try to see if there's anything you may have missed, if you think you're good, end the inspection by saying "And that concludes my pretrip inspection of a Class A Combination Vehicle"
now if I have missed ANYTHING here, please feel free to correct me truckers! Hope this helps you out.
ruckusftlc, jvar4001 and lionheart0901 Thank this. -
One thing i failed to mention in my last post was Torsion Bars, if you're inspecting a vehicle with Torsion Bars, it would go like this:
Torsion Bars - PMS not cracked, Bent or Broken.jvar4001 Thanks this. -
Pre Trip Inspection
1. Check that all the documents (Bill of lading, Manifest, Permits) match the cargo you are hauling
2. Make sure you have the right truck and trailer
3. Review the Post-Trip inspection report and make sure that any listed problems are repaired and signed by the mechanic
4. Put the Key IN your pocket so no one can move the truck while your doing your pre trip
5. Look Under the vehicle for fresh OIL, COOLANT, GREASE, or FUEL leaks
6. Look Under the vehicle for anything hanging off of the truck or trailer
7. Check to make sure there isn't anything on the ground that you'll run over when you move the truck
8. Face the front of your vehicle and check to make sure it is not leaning to one side indicating 1 or more flat tires/ Broken suspension components, Shifted/improperly loaded or over loaded trailer
FACE TRUCK and START FROM THE TOP!
1. AIR SHIELD-Properly mounted and secured not cracked bent, or broken
2. I.D CLEARANCE LIGHTS- Properly mounted and secured not cracked bent or broken, good rubber seal, no moister, amber in color and function properly
3. HORN- Properly mounted and secured not cracked, bent or broken
4. WINDSHIELD- Properly mounted and secured not cracked, bent or broken, good rubber seal, clean, no illegal stickers
5. WINDSHIELD WIPERS- Properly mounted and secured not cracked, bent or broken, good rubber on the blades, and good tension on the wipers
6. HOOD LATCHES- Properly mounted and secured not cracked, bent or broken
7. GRILL-- Properly mounted and secured not cracked, bent or broken, nothing blocking airflow to the radiator
8. HEAD LIGHTS- - Properly mounted and secured not cracked, bent or broken, good rubber seal, no moister, clean, clear in color, function properly
9. TURN SIGNALS-- Properly mounted and secured not cracked, bent or broken, good rubber seal, no moister, clean, clear in color, function properly
10. BUMPER- Properly mounted and secured not cracked, bent or broken
11. LICENSE PLATE- Properly mounted and secured not cracked, bent or broken, clean, up to date
12. HOOD MIRRORS- Properly mounted and secured not cracked, bent or broken, good rubber seal, clean
OPEN HOOD
RIGHT SIDE OF ENGINE COMPARTMENT
1. RADIATOR- Properly mounted and secured not cracked, bent or broken, free of dents, inspect the fan for missing blades, look for hanging wire that can catch on the blades
2. OIL LEVEL- Make sure between full and add marks, check to make sure there is NO Water or DIESEL in the oil
3. ALTERNATOR- Properly mounted and secured not cracked, bent or broken, check all wires make sure there all, Properly mounted and secured not cracked, bent or broken, or frayed. NO more then ¾ of an inch of play in the middle of the belt
4. WATER PUMP- Properly mounted and secured not cracked, bent or broken, NOT LEAKING, check all HOSES going to and from to be sure there, Properly mounted and secured not cracked, bent or broken, NOT LEAKING
5. TURBO- Properly mounted and secured not cracked, bent or broken, NO LEAKING
6. S PIPE AND FLEX PIPE- Properly mounted and secured not cracked, bent or broken, NO LEAKS soot trail would indicate a leak
7. EXHAUST ELBOW- Properly mounted and secured not cracked, bent or broken, NOT LEAKING soot trail would indicate a leak
8. EXHAUST MOUNTING BRACKET- Properly mounted and secured not cracked, bent or broken
9. EXHAUST SYSTEM- Properly mounted and secured not cracked, bent or broken, NO LEAKS soot trail would indicate a leak
LEFT SIDE OF ENGINE COMPARTMENT
1. COOLANT LEVEL- make sure the reservoir is, Properly mounted and secured not cracked, bent or broken, check level threw reservoir/sight glass, or open cap DO NOT OPEN WHILE HOT!
2. AIR COMPRESSOR- Properly mounted and secured not cracked, bent or broken, NOT LEAKING
3. WINDSHIELD WASHER FLUID- Properly mounted and secured not cracked, bent or broken, NOT LEAKING, add more if needed, USE DE-ICER in winter
STEERING AND LINKAGE SYSTEM
1. POWER STEERING RESERVOIR- Properly mounted and secured not cracked, bent or broken, NOT LEAKING, and fluid between FULL and ADD
2. STEERING WHEEL SHAFT- Properly mounted and secured not cracked, bent or broken, Universal joint not loose and PROPERLY greased
3. GEAR BOX- Properly mounted and secured not cracked, bent or broken, NOT LEAKING
4. PITMAN ARM- Properly mounted and secured not cracked, bent or broken, GOOD PINCH BOLT
5. CASTLE NUT AND COTTER KEY- Properly mounted and secured not cracked, bent or broken
6. DRAG LINK- Properly mounted and secured not cracked, bent or broken
7. UPPER AND LOWER CONTROL ARMS- Properly mounted and secured not cracked, bent or broken, Good castle nuts and cotter keys
8. TIE ROD- Properly mounted and secured not cracked, bent or broken
FRONT SUSPENSION SYSTEM
1. FRONT AND REAR SPRING MOUNT- Properly mounted and secured not cracked, bent or broken, no missing bolts
2. LEAF SPRINGS- Properly mounted and secured not cracked, bent or broken, NO MORE the ¼ broken or missing
3. U-BOLTS- Properly mounted and secured not cracked, bent or broken, check for shiny threads indicating that there loose
4. SHOCK ABSORBERS- Properly mounted and secured not cracked, bent or broken, NOT LEAKING, rubber bushing top and bottom
5. AIR BAGS- Properly mounted and secured not cracked, bent or broken, no holes, NOT LEAKING, and check bottom BELL is not cracked or broken (If air ride equipped)
AIR BRAKE SYSTEM
1. BRAKE CHAMBERS- Properly mounted and secured not cracked, bent or broken, good C-Clamp, NOT LEAKING
2. SLACK ADJUSTER- Properly mounted and secured not cracked, bent or broken, NO more then 1 inch of free play with the brakes released
3. BRAKE LINES- Properly mounted and secured not cracked, bent or broken, NOT LEAKING
4. BRAKE PADS- Properly mounted and secured not cracked, bent or broken, at LEAST ¼ of an inch of pad
5. BRAKE DRUM- Properly mounted and secured not cracked, bent or broken, NO oil or discoloration indicating overheating
FRONT WHEELS
1. RIMS- check inside and out side to make sure that it's, Properly mounted and secured not cracked, bent or broken, no illegal welds
2. TIRES- Properly mounted and secured not cracked, bent or broken, check inner and outer sidewall for ABRASIONS, BRUISES, and CUTS, at LEAST 4/32's of an inch of tread in ALL major grooves, TIRE pressure 100-110
3. LUG NUTS- Properly mounted and secured not cracked, bent or broken, NO rust trails or shinny threads indicating that there loose
4. VALVE STEMS- Properly mounted and secured not cracked, bent or broken, NOT LEAKING, and has METAL dust cap
5. HUB SEAL- Properly mounted and secured not cracked, bent or broken, NOT LEAKING, NO MISSING BOLTS, check level if low add 90 weight gear oil
LEFT SIDE OF TRACTOR
1. SPLASH GUARDS- Properly mounted and secured not cracked, bent or broken
2. MIRROR BRACKET- Properly mounted and secured not cracked, bent or broken
3. MIRRORS- Properly mounted and secured not cracked, bent or broken, good rubber seal, no moister, clean
4. DRIVER DOOR- Properly mounted and secured not cracked, bent or broken, make sure inner and out door latch work and that window goes up and down, good rubber seal, door hinge holds the door
5. SADDLE STRAPS- Properly mounted and secured not cracked, bent or broken, there MUST be rubber between straps and tank
6. FUEL TANK- Properly mounted and secured not cracked, bent or broken, NOT LEAKING
7. FUEL CAP- Properly mounted and secured not cracked, bent or broken, have inner and out rubber seal and functioning pressure release valve
8. GRAB HANDLE AND STEPS- Properly mounted and secured not cracked, bent or broken, and can hold the weight of the driver, and free of debris
9. OVERALL SIDE OF TRACTOR- No damage, missing rivets, Sleeper window not cracked or broken and good rubber seal
10. SIDE COMPARTMENT- check to make sure door is Properly mounted and secured not cracked, bent or broken, and there MUST be 3 DOT triangles, a FUSE for every fuse used in the truck UNLESS the truck is equipped with breakers, and there Must be a 5BC Fire Extinguisher if you are not hauling HAZMAT and a 10BC if you are hauling HAZMAT
11. BATTERY BOX- Properly mounted and secured not cracked, bent or broken, good connections to the batteries no excessive corrosion, wires in good condition
REAR OF TRACTOR
1. CATWALK/STEPS/GRAB HANDLE- Properly mounted and secured not cracked, bent or broken, and can hold the weight of the driver
2. DOT TAPE- Properly mounted on rear of sleeper and CLEAN
3. AIRLINES/ELECTRICAL PIG TAIL- Properly mounted and secured not cracked, bent or broken, NOT LEAKING
4. DRIVE SHAFT- Properly mounted and secured not cracked, bent or broken
5. U-JOINTS- Properly mounted and secured not cracked, bent or broken, and greased
6. FRAME AND CROSS MEMBERS- Properly mounted and secured not cracked, bent or broken, no missing bolts or illegal welds
7. FIFTH WHEEL- Properly mounted and secured not cracked, bent or broken, AND greased, (if no trailer is attached it should be tilter back towards the trailer
8. FIFTH WHEEL MOUNTING BOLT- Properly mounted and secured not cracked, bent or broken, (IF SLIDING FIFTH WHEEL Make sure locking pins are in the locked position
9. FIFTH WHEEL PLATFORM- Properly mounted and secured not cracked, bent or broken
10. RELEASE ARM- Properly mounted and secured not cracked, bent or broken, IN THE LOCKED POSITION WITH SAFETY LATCH IN PLACE
11. PIVOT PINS- Properly mounted and secured not cracked, bent or broken, good cotter keys
12. LOCKING JAWS- Properly mounted and secured not cracked, bent or broken, (IF ATTACHED TO TRAILER LOOK INTO THE THROAT OF THE FIFTH WHEEL AND MAKE SURE ITS LOCKED AROUND THE SHANK OF THE KING PIN AND NO GAP BETWEEN FIFTH WHEEL AND THE APRON OF THE TRAILER
SUSPENSION SYSTEM
6. TORSION BAR- Properly mounted and secured not cracked, bent or broken
BRAKES
RIMS AND TIRES
1. RIMS INNER AND OUTER- check inside and out side to make sure that it's, Properly mounted and secured not cracked, bent or broken, no illegal welds, NO debris between rims (IF it has DAYTON rims check to make sure spacer is there and not cracked or broken)
2. TIRES INNER AND OUTER- Properly mounted and secured not cracked, bent or broken, check inner and outer sidewall for ABRASIONS, BRUISES, and CUTS, at LEAST 2/32's of an inch of tread in ALL major grooves, TIRE pressure 100-110
4. VALVE STEMS INNER AND OUTER- Properly mounted and secured not cracked, bent or broken, NOT LEAKING, and has METAL dust cap
REAR DRIVE AXLE
SAY: I'm going to check this axle the SAME way I checked the front drive axle and name off all the parts your going to check (you DO NOT need to point to or describe them or say what you're checking for)
REAR OF TRACTOR
1. MUD FLAPS- Properly mounted and secured not cracked, bent or broken, and should be NO MORE then 6-8 inches off the ground
2. REAR LIGHTS- Properly mounted and secured not cracked, bent or broken, good rubber seal, no moister, red in color and function properly and have the 4 functions of TAIL LIGHTS, BRAKE LIGHTS, 4 WAYS, TURN SIGNALS
TRAILER
1. FRONT OF TRAILER- Check for damage and missing rivets, and check trailer inspection and registration are up to date
2. AIR AND ELECTRIC CONNECTIONS- Properly mounted and secured not cracked, bent or broken, make sure glad hands have good seals
3. CLEARANCE LIGHTS- Properly mounted and secured not cracked, bent or broken, good rubber seal, no moister, function properly, and should be amber in color
Look down left side of trailer
1. TRAILER FRAME- Make sure its straight and no missing rivets
2. OVERALL SIDE OF TRAILER- No damage, no missing rivets, and has DOT tape on ALL sides of the trailer
3. SIDE MARKER LIGHTS- Properly mounted and secured not cracked, bent or broken, good rubber seal, no moister, amber in color on front and side and red in color at rear and function properly
4. TRAILER APRON- Properly mounted and secured not cracked, bent or broken, AND greased
5. KING PIN- Properly mounted and secured not cracked, bent or broken, NO flat spots, and should have a ping sound when taped with a hammer
6. LANDING GEAR- Properly mounted and secured not cracked, bent or broken, CHECK CROSS MEMBERS, make sure handle rests in cradle and works in high and low gear, and both sides come down evenly, and the sand feet are Properly mounted and secured not cracked, bent or broken, and free of debris
7. FLOOR AND FLOOR CROSS MEMBERS- Properly mounted and secured not cracked, bent or broken, no holes in floor
8. AIR LINES UNDER TRAILER- Properly mounted and secured not cracked, bent or broken, at LEAST 18 inches off the ground
9. TANDEM SLIDE RAILS- Properly mounted and secured not cracked, bent or broken, locking pins and release lever in the LOCKED position
FRONT TRAILER TANDEM AXLE
SUSPENSION SYSTEM
4. AIR BAGS- Properly mounted and secured not cracked, bent or broken, no holes, NOT LEAKING, and check bottom BELL is not cracked or broken (If air ride equipped)
BRAKES
RIMS AND TIRES
REAR DRIVE AXLE
REAR OF TRAILER
1. REAR LIGHTS- Properly mounted and secured not cracked, bent or broken, good rubber seal, no moisture, red in color and have the 4 functions of TAIL LIGHTS, BRAKE LIGHTS, 4 WAYS, TURN SIGNALS
2. DOT BUMPER- Properly mounted and secured not cracked, bent or broken, has DOT tape on it
3. DOORS- Properly mounted and secured not cracked, bent or broken, no damage, has DOT tape on them, latches and hinges work, and has door ties to hold doors open
4. MUD FLAPS- Properly mounted and secured not cracked, bent or broken, no more then 6-8 inches off the ground
5. LICENSE PLATE- Properly mounted and secured not cracked, bent or broken, clean, up to date, and license plate light works
INSIDE THE CAB
1. ROLL DRIVER WINDOW DOWN- To listen and smell anything that might be wrong
2. DRIVERS SEAT- Properly mounted and secured not cracked, bent or broken, and adjusted for the driver
3. SEAT BELT- Properly mounted and secured not cracked, bent or broken, not frayed and latches properly
4. MIRRORS- Properly mounted and secured not cracked, bent or broken, AND adjusted for the driver
5. WINDSHIELD- Properly mounted and secured not cracked, bent or broken, no illegal stickers
6. STEERING WHEEL- Make sure there isn't more then 2 inches of play in a 20 inch steering wheel
7. PUT KEY IN IGNITION
a. Tell instructor your going to start the truck and will be watching your OIL PRESSURE gauge, and that if the pressure does not start to rise within 5 SECONDS your going to shut the truck off
b. Start truck and watch oil pressure
c. Check all other gauges to make sure they are functioning
d. Say: Low air pressure light and buzzer should be on and remain on until the air pressure builds to at least 60 PSI
8. While the air pressure is building:
a. Check Heat and defrost make sure the work
b. Check wipers and washers
c. Check light indicators on dash (high beams, left and right turn signal and 4 ways
d. Raise RPM's to 1200-1500 until air pressure stops rising should stop between 100-125 PSI
e. Check horns CITY HORN and HIGHWAY HORN
9. Put truck in 1st gear and release the Tractor brakes (Push in Yellow Button)
a. Slowly release clutch until you feel the truck tug on the trailer, and then push the clutch back in, what your checking here is that the fifth wheel is locked, Trailer spring/Parking brakes work, and that your tandems are locked.
10. SHUT THE TRUCK OFF with the transmission still in 1st
a. Turn the ignition back on but NOT the truck
b. Release the Trailer brakes (push in the red button)
c. After the initial drop in air pressure make sure that you DO NOT lose more then 3 PSI in a minute
d. Then fully apply service brake (the foot brake) and hold it you should not loose more then 4 PSI in a minute
e. Begin pumping down the brakes, the low air pressure alarm and light should come on when the air pressure drops below 60 PSI
f. The Red and Yellow button should pop out when the air pressure is between 20-40 PSI the red button should pop out first if not you have a problem, What your checking here is your tractor protection valve
11. Ask the instructor if he/she wants you to get out and check your lights
12. Then shut the ignition off and say: "That completes my pre-trip inspection".
ADDITIONAL THINGS TO DO IN REAL LIFE AFTER YOUR TEST
1. Do a tug test with the Red button pushed in and the yellow one out to check the Spring/Parking brakes on the tractor
2. After both tug test release both tractor and trailer (push both buttons in) and roll forward and press the brake pedal to check service brakes
3. Roll forward some more and just apply the trailer service brakes with the Trolley bar on the steering column or dash board to check the service brakes on just the trailer.
I just typed this all up the other day for the new instructor at the school I'm doing my refresher course at because the school teaches a VERY poor pre trip.
American Truckerjvar4001 and lionheart0901 Thank this. -
Be methodic about it.
That is do it like a book. Start at the top left and work your way right and then down.
Cold engine check -Right Side - Left Side
In cab check. Start at the Smokers window and work your way across and down until you get to the floor.
Get out and do your hot engine check
Close the hood, latch the left, checking that side
Go to the left checking as you go across.
Latch the left side
Continue working your way around vehicle checking as you go in a methodical manner.
I have had the opportunity to drive many different trucks and this has worked for me.
94, 99, 07, 08, 10 International Tractors
07,08,10 Freightliner Columbia
96,97,98 FL 70's
07 International Straight Truck
01 Mack Tractor
97 Mack Redi-Mix Truck
94 International Redi-Mix Truck
Just what I can remember driving. Such is life as a local driver.leadfoot80, jvar4001 and lionheart0901 Thank this. -
Thank you all for the comments I am going to print them out and study from them. You all really went above and beyond what I was expecting as comments and I truly appreciate it. Thank you all God Bless drive safe.
WVroadtrucker1965, jvar4001 and American-Trucker Thank this. -
The way I learned my pre-trip is this way! If you do it in this order you will not fail!
1) start with the front of the tactor,
Lights and reflectors
Under the tactor
leaks and puddels
2)Passenger side
Water pump
Alternator
Oil Level
Plus all other hoses and wiring
3)Drivers side
Coolant
Power steering reservoir
Air Compressor
Steering gear box
Streering linkage(pitman arm, drag link, steering Knuckle, tie rod and tie rod end castel nuts and cotter pins)
4)Front Suspension
Spring Mounts
Leaf springs
Shock absorber
5) Front breaks
Hoses and Lines
Chamber
Slack adjuster
drums
linings
6) Front Wheels
Tires
rims
lug nuts
outer hub oil seal
7)Driver Fule Area
Driver door
driver mirrors
Fuel tank
8)rear of tactor(inbetween tactor and trailor)
Air lines and electrical lines
Battery box
catwalk
drive shaft
exhaust system
frame
ultilty lights
(can remember this part by A,B,C,D,E,F,U)
9)Trailor front
Lights and refelctors
header board
10)Drive axles
Control arm mounts
control arms
torsion bar
shock absorer
air bags
11)Drive breaks
Hoses and lines
chamber
slack adjuster
drums
linings
12)Drive wheels
tires
rims
lug nuts
outer axle seal
space or spacer
13) Coupling system
mounting bolts
release arm
locking pin
air line
platform
skid plate
king pin
apron
gap
jaws
14) Rear of Tractor
lights and reflectors
splash guards(mud flap)
15)Trailer Side
landing grear
frame
tandem release
lights and refeltors
16)Rear of trailer
doors
door ties
splash guards
DOT bumper
lights and refletors
17) metion gonna check the passenger side as you checked the driver side.
18)In Cab
Emergency Equipment
safty belt
steering wheel
clutch
shifter(enclude range selector too)
water temp gauge
voltmeter
lighting indicators
horn(both)
heater&defrost
windshield
wiper and washer
driver and passenger mirrors
19) Start your tug test then move on to your 4 point break check
Hope this helps it helped me if you do it in this order you will not fail itjvar4001 and lionheart0901 Thank this. -
WOW ! THANK YOU GUYS NOW IM GOING TO LOOK FOR THE AIR BREAK CHECK! [email protected]
