Preference: Weight On Drives Or Trailer?
Discussion in 'Experienced Truckers' Advice' started by Grumppy, Jul 29, 2014.
  1. Grumppy
    3,234
    11,403
    Dec 11, 2010
    West Monroe, La
    I'm just wondering from you guys...
    When you have the option (under gross) would you prefer to have the weight balanced /about equal on the trailer axles & the drive axles? OR
    Would you prefer a little more of your weight on the drives or the trailer. Does it make a difference in ride or lugging/load/pulling hard on the truck etc?
    Here is what I had today:
    Steers: 11180
    Drives: 33440
    Trailer: 32360
    Gross: 76980
    Do you like a little (or a lot) extra on the drives, OR
    would you have moved that extra weight to the trailer & off the drives, OR
    would you have moved 1/2 that weight (540 Lb) to the trailer & had equal weight?
    Why would YOU do that? Preference? Ride? Lugging truck/pulling more/less? Just like it balanced? Truck/trailer stability?
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    How much fuel you have?
  4. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    I always prefer to have more weight on the drives if the final position of the trailer tandems is not too far back to make turns an issue. I do this for the ride improvement generally speaking, but for the added traction on snow/ice when applicable.
    Battle Born Thanks this.
  5. bigkev1115
    bigkev1115 Road Train Member
    2,364
    3,618
    Oct 23, 2009
    Alexandria, AL
    Me personally if I had a full tank, and that was my weight, I would slide my tandems forward to balance out the weight. To me it rides better balanced. You may see some O/O s put all the weight on the trailer so that they re not wearing out their tires if they are leased to a company
    Grumppy Thanks this.
  6. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    Personally, I prefer the weight up front. I always like to roll with the tandems around the 8th hole, unless the load is too heavy in which case I move it around. Plus, if you're ever over weight, put the weight on the drives. You can burn the fuel off.
  7. gentleroger
    gentleroger Road Train Member
    7,898
    21,619
    Jun 1, 2010
    I prefer to have the drives heavier by no more than 500 pounds. This gives me the smoothest ride and appears to give me better fuel economy.
    I use 500 because I will burn off just over 1/2 of a pound a mile off my drives in fuel. This way my drives will stay heavier during the entire run.
    Grumppy and rcpilot Thank this.
  8. Grumppy
    3,234
    11,403
    Dec 11, 2010
    West Monroe, La
    I was full of fuel today when I weighted. Two 120 gal tanks.
  9. Grumppy
    3,234
    11,403
    Dec 11, 2010
    West Monroe, La
    Very helpful... thanks.
  10. MACK E-6
    50,050
    238,537
    My personal preference is to err on the side of having more weight where you can control it.
    Battle Born and Grumppy Thank this.
  11. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Personally I would have probably bumped the trailer up another hole. I agree, I liked to keep weight on the drives, it does ride smoother.
