Pretrip Light inspection mode
Discussion in 'International Forum' started by alanarbor, Mar 17, 2022.
  1. alanarbor
    alanarbor Bobtail Member
    Mar 17, 2022
    Thanks Received:
    I was unaware that my 2007 international 4200 had this feature until yesterday when I accidentally activated it. It cycles through all the lights making the pretrip a lot easier.
    However I have no idea what I did, and I'd like to be able to do it again. Owners manual is long gone. Anyone know how to repeat this?
    D.Tibbitt Thanks this.
  2. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,826
    Thanks Received:
    6,276
    Look for the LMP switch on the left side of the cluster near the head light switch. Press it with the key on or in acc.
  3. alanarbor
    Mar 17, 2022
    Thanks Received:
    My truck is a 2007, it doesn't have the lamp switch. It was a combination of cruise switch presses that triggered it, so it could be a diagnostic mode, but I haven't been able to repeat it.
  4. Heavyd
    Feb 4, 2009
    7,826
    Thanks Received:
    6,276
    Ok, I found this,
    DESCRIPTION
    Vehicles with DLB feature code 595AES do not have a dedicated Exterior Lamp Check switch located beside the headlight switch.
    To activate this feature, insure no other exterior lights are on, park brake is set, turn the ignition switch to either ACC or IGN position, momentarily depress both the cruise/throttle ON and RESUME/ACCEL buttons at the same time, then depress the brake pedal.
    To deactivate the check, either depress the brake pedal again or activate any of the exterior lights being checked. The bulb check will deactivate automatically in 10 minutes if not cancelled manually.
  5. alanarbor
    Mar 17, 2022
    Thanks Received:
    Thank you! This will make my life so much easier!
  6. flood
    flood Road Train Member
    Dec 25, 2010
    4,168
    Thanks Received:
    4,047
    on my truck doing this brings up the ecm diagnostic screen
