Hello
I purchased a 2007 Peterbilt 387 with C15. The primary air buzzer stays on and the air pressure stays at zero. There is no air leak anywhere. I changed the primary air gauge on the dash and still the same issue. Anyone had this issue? Thank you
Primary Air buzzer stays on
Discussion in 'Peterbilt Forum' started by kloria, Sep 26, 2020.
If your standing behind the truck. On the left side there is a bar, it’s hooked up to a valve with about I think 2 or 3 air hoses. Sometimes my looses air pressure. That’s where it always is ? Sometimes that bar leans to one side and causes a leak. I hope this helps ya out. B safekloria Thanks this. -
Thank you, I will check it out. I was also told maybe it's the pressure switch located inside the dash PART#Q27-1038
