I had the same problem couple yrs ago, and thanks to handlebar its cured! Mine was caused by synthetic axle lube, that was non conductive. The only difference in our posts is my static would quiet as I applied the brakes. And I tested the theory using bungee cords attached to frame, I could hear them clear the static each time they touched the asphalt.
My solution; a bottle of graphite (32g) $5 squeezed into both front axel hubs. You could hear them turning through the static for 150-300 miles then problem solved. I'm sure no one in their right mind would suggest adding metal into gear lube as a good idea! but it has worked for 300,000mi since. A better suggestion may be to ignore the synthetic lube only stickers?
Problem with road noise-static
Discussion in 'CB Radio Forum' started by jammer 463, Jan 11, 2016.
Page 2 of 2
Page 2 of 2
