Problem with Volvo I-shift AT2612F
Discussion in 'Volvo Forum' started by idjaidy, Feb 20, 2021.
  1. idjaidy
    idjaidy Bobtail Member
    8
    Hi
    I have a problem with my I - shift transmission on volvo FM (4) M.Y 2018, the problem is too late downshifting, the RPM reaches 10000 rpm then the transmission downshifts, the truck lose power because of this late shifting,
    in the past it was downshifting at 14000 rpm it was ok,
    no diagnostic trouble code appears on Engine or transmission,
    any ideas?
    Regards
  3. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Do you have an E/P button on your shifter? What does the dash say? E or P next to the current gear?
  4. idjaidy
    8
    Yes i have, the problem exist with both E or P on the dashboard.
    It works fine - shifting at higher rpm- only when i press B ( brake mode) in the engine brake control lever.
    I need it to downshift always like that at higher rpm.
    Thanks to your reply
  5. bad-luck
    bad-luck Road Train Member
    3,446
    6,356
    Nov 16, 2013
    Baltimore, Maryland
    @Goodysnap
