Problems With 2012 Cascadia and Schneider Maintenance
Discussion in 'Schneider' started by Donnie1, Jan 1, 2014.
  1. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    that would be where I pointed them too. be real cool and ask about in a general way with one of the mechs who seem cool. Most are , but are restricted in what they can almost f not more so than we are. They would just soon fix it all , cost be ######. They get it, GB does not.
  3. Donnie1
    Donnie1 Light Load Member
    53
    12
    Nov 28, 2011
    Sedalia, Mo
    UPDATE:
    So last night it was 9 degrees out and my truck idled. So I guess the magic # is probably 10 degrees. I left the truck idling and went to bed. At 0234 the truck cut off which woke me up, yes it 0234, I looked at my phone. I restarted it and and saw that it was 12 degrees now so it would not idle any more. I had plugged my CPAP into the truck verses the batt since the truck was idling and decided to leave it that way since I was getting up at 0545 anyway. Figured since I had been idling for 6 hours the batts would be good. I also left my cooler plugged in. I was then awakened at 0431 by the batt warning dings and they then shut off.
  4. atruckr
    atruckr Road Train Member
    1,759
    2,643
    May 14, 2011
    Victorville CA
    If you would like to stay on with SNI I would make an effort to get their attention on this. What your dealing with is BS and no one wants to take the time to do what is necessary to get you operating profitably. Personally I would write a letter to the head DBL of your OC explaining what your dealing with trying to run that truck and why you will leave unless they give you a different one that runs like it should. Then ask for time at home and when you get to the OC clean out your truck nice and clean and take the keys into your DBL and simple say respectfully.. "here are the keys to my truck, I cleaned it out for ya! I like working here and working with you but this truck is just not worth all the trouble. If you can find a better truck for me then I would be glad to come back to work here. Otherwise I will be forced to find a job elsewhere". Then walk away and deliver the letter to the Head DBL and leave. Actions speak louder than words! See if they won't call you back with a different truck for you. If they don't then move on!
  5. WI Cupcake
    WI Cupcake Light Load Member
    73
    37
    Dec 2, 2013
    You need to stand up to our mechanics. They will b***h and moan about having to be more than a parts changer, but it's up to you. Remember, FMCSA regs state that if you pretrip or otherwise inspect and are dissatisfied with the maintenance of your equipment, nobody - not a DBL, not his boss, not the CEO of the dang company - can force you to run. I have had my rig into the shop too many times to count.
    Had an effed up headlight that I mentioned at my last PM. PM didn't take care of it. Next stop was Gary. Reaimed the light and didn't address the poor beam pattern. Made it worse. Edwardsville - reaimed again. Made it all but impossible to operate in the dark.
    Dealt with it for a few days, and ended up back in Gary. They gave me a buffing kit and sent me to express. They buffed and buffed and buffed and couldn't fix the beam. They were sure it was the lense. Got to a point where they said "well that's as good as it'll get..." I told them "look at my other side. It looks like you would expect. Now look at this one. A man who's blind in one eye and can't see out the other could tell you a headlight beam isn't suppose to look like that! Can I please just get a new headlight assembly?!" I got a roll of the eyes out of the dork in express, and he started writing up the new assembly. And of course since that whole run-in, my lights are great.
    As I said, it's up to you to get something done. It's up to you to be a big enough pain in the rump that they have to take care of your truck. I hate having to be like that myself, and like it even less that I have to give you that advice, but it's the only way to get something accomplished.
  6. Donnie1
    53
    12
    Nov 28, 2011
    Sedalia, Mo
    I have been checking with other companies around the area and have had 2 offers from a company and was told when I am ready to come to work for him that he will make a place for me. I was in Edwardsville on Thur and Al from the night shift put the computer on it for the idling and he said it had some parameters that were out and wasn't right. He updated it but I have been home for the weekend so I have not had to idle. I told him about the batts and he also said that they should have changed all 4 at the same time. I will be having my PM thru there in a week or so and he said they will change them. Al is the best one I have ever dealt with at any OC. I have my vacation scheduled for the week of 10 Feb. After that, if I have any other problems with the truck, I will be giving the ultimatum. I do like working for Schneider and I have a great DBL. Writing a letter to the head DBL will do no good at all. I did receive the last quarter bonus and it was $100 lower than the last bonuses so I can honestly say that this truck has cost me money due to the breakdowns.
  7. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    I hope they can get everything fixed up for you. The battery deal is a typical beancounter move, replacing one battery on a set of already worn/used batteries - they'll constantly fight eachother and drag eachother down until the whole set is ruined again. If you have a good working set of batteries it should be no problem to run your bunk heater at a comfortable temperature for the full 10 hour break, along with a little bit of TV, etc., usage. If they aren't, there is a problem.
  8. 91B20H8
    91B20H8 Road Train Member
    2,946
    3,315
    Oct 17, 2012
    The Heart of the North, Mi
    I was at That oc just a few days ago too and Al tried with mine but his computer wouldn't link to my truck. I agree, he's the only one worth dealing with out of all the ocs i have been to
  9. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    I'm in my 4th 2012 Cascadia since starting at Swift. Not one of them has been capable of 10 continuous hours of bunk heater or running a 12v cooler more than a few hours before having to crank up the engine to recharge the batteries. Might be an issue related to the design of the Cascadia electrical system, or could be they are simply using cheap batteries. In that regard it seems the experience is the same with what you have at Schneider.
  10. TruckerPatrick86
    TruckerPatrick86 Medium Load Member
    601
    217
    Dec 12, 2012
    Central Florida
    Al in Edwardsville is a really cool guy. I met him for the first time the other week when I was routed there to get a new black box for my qualcomm and he was great.
  11. CaptainX3
    CaptainX3 Road Train Member
    1,408
    1,057
    Nov 10, 2011
    Fort Worth, TX
    It sounds like they're not using high quality batteries, or they're not changing out the entire set. When I was working for Maverick, I had a 2012 Cascadia where the batteries wouldn't last but 3 hours or so. They changed the entire set, and from then on I'd get about 9 hours or so of full power running a cooler, TV, DVD player, and all of my stuff up front like the Qualcomm, GPS, dash camera, etc. Once that 9 hours was up, the truck would shut down power to the power ports in the bunk area and shut off the interior lights, but the climate control would keep going for at least another 3 hours after that.
    But, that whole system goes out the window if even ONE battery is bad.
