Problems with 5 speed Split shift
Discussion in 'Experienced Truckers' Advice' started by SirTJ79, Oct 23, 2011.
  1. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    We had those at Pepsi. Old dog Ford F700's with 5 X 2's. One had a turbo 3208 Cat and would do 75 mph flat out with the engine screaming at 2300 rpm. I think I suffered hearing loss in that truck, lol but it was a blast the few times I took it on my route.
    ampm wayne Thanks this.
  3. SirTJ79
    SirTJ79 Bobtail Member
    19
    Oct 23, 2011
    Talked to 1 guy today and supposedly I am driving this split shift all wrong...the way he made it out...I am supposed to be pulling up and down on that button throughout each gear shift????
    Still a little confused???
  4. Hammer166
    7,580
    27,635
    Aug 18, 2007
    ~8600+' and loving it!
    If remember right, aren't there a couple different setups with these?
    I know some you split every gear, they shift like a super10. But others I'm thinking you do 1L-2L-3L-2H-3H-4L-4H-5L-5H. Or am I remembering something else?
  5. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    I think his is one that goes 1l 1h 2l 2h and so forth used to drive one just like it red and all.
    Hammer166 Thanks this.
  6. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    The ones at Pepsi you split gears 2 - 5, 1st gear was left in low, though you could still split 1st gear.
  7. SirTJ79
    19
    Oct 23, 2011
    this is how im imagining it....So in order to shift like this..when do i push in the button and there is no clutch used when pushing in the red button again correct??
    I think i got this down, but then some other guy tells me, just leave it in high, it will pull no problem...
    Says messing with the splitter so much will just cause problems??
  8. Hammer166
    7,580
    27,635
    Aug 18, 2007
    Somebody said it further up, but when you shift, you move the lever first, then the button. This way the trans and rear are never in neutral at the same time. So, like this: 3L-select high-off/on throttle-3H-shift lever to 4th-select low-on throttle-4L... You shift the 2-speed just like a splitter on a 13/18 or Super10 except that you shift the splitter after the shift instead of preselecting.
  9. Johnny99
    Johnny99 Johnny be Good
    549
    261
    Nov 24, 2007
    Big Sandy Tenn
    Sounds like it might be one of the old 2 speed axles. If it is the button controls the rear gear ratio. Red button, electrically operated. If it is working properly you start out with the button down, the next shift pull the button up with the accelerator depressed, let off the gas and it should shift by itself then mash the gas again. Next shift, with the button still up shift to the next highest gear, after you complete the shift try to coordinate pushing the button down just as you let out on the clutch and then immediately hit the gas. Progressively go thru the gears like that. To downshift from button up to button down in the same gear, with the gas pedal depressed just push the button down, let off the gas for a split second, then mash it again. The next shift, button down with the gas pedal depressed, pull the button up then move the gear stick to the next lowest gear. Takes a little getting used to if you are used to a 9, 10, or 13 speed. If you ever drove a Super 10 its very similar in the way you shift it.
  10. Johnny99
    549
    261
    Nov 24, 2007
    Big Sandy Tenn
    If the thing isn't engaging half the time as you say, make sure you are letting off the gas pedal completely. If it is a 2 speed axle there may be some moisture in the electrical box.
  11. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    Just to add to the confusion, it has what is called a working 5th you shift
    4L 5L then 4H 5H to get the right progression of gears.
